Old 11-21-2018, 06:41 PM #1
Tomffmedic Tomffmedic is offline
Tomffmedic is on a distinguished road
Rear Hatch Latch
I noticed my dome light wasn't working in the cargo area. I took it apart and found it to be broken where the bulb is held in by tension. I bought a used rear cargo light assembly and replaced it. I turned it to door and it still didn't operate only worked in the on position. I took the plastic cover off the back hatch to chase wires. I found a clip disconnected. I thought that was weird but whatever. I put it back together. Now my light stays on unless I turn it to the off position. Also the door ajar dash light is on 24/7 now. I pushed on the back door when it was closed and it went off. I have tried every avenue to adjust the latch to get it to operate properly. I opened the hatch and used a screwdriver to act as the pin for closing the latch. I can push it 1/4" further with the screwdriver and it turns the light off. There is no resistance when I use the screwdriver. What am I missing here?
Tomffmedic is offline   Reply With QuoteReply With Quote
Old 11-21-2018, 08:57 PM #2
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
The striker might could use some adjusting.
Old 11-22-2018, 01:54 AM #3
Slobo's Avatar
Slobo Slobo is offline
Slobo is on a distinguished road
Slobo's Avatar
I have similar problem, if I dont slam it the light stays on but the hatch is fully closed, PO took some rear damage to the hatch but everything seems to be mechanically okay, hook on bumper seems okay, havent check out the door latch yet.
1998 4Runner 3RZ 2WD Auto #671
RIP 2003 4Runner V8 Limited
RIP 1990 Celica GT
https://imgur.com/a/z8yIGRf?grid
Slobo is offline   Reply With QuoteReply With Quote
Old 11-22-2018, 02:05 AM #4
I have tried to figure out what to adjust. Nothing seems to have any adjustment to it. I removed the striker and the latch both in direct holes no slide to them. Is there something I am missing?
Old 11-22-2018, 09:34 AM #5
Carova Colton Carova Colton is offline
Carova Colton is on a distinguished road
Same problem
I pulled apart and clipped the red wire. It won’t display the door open icon anymore but I couldn’t fix and had enough.
Carova Colton is offline   Reply With QuoteReply With Quote
Old 11-22-2018, 10:34 AM #6
Real Name: Mark
Real Name: Mark
@Tomffmedic , FSM says to loosen two phillips screws on striker (attached to body) and move it left right forward rearward. I had the light not working one time in door mode, I lubed latch which also lubed the switch that controls light. Your switch may need some attention.
Old 11-23-2018, 11:48 PM #7
If you cut red wire does the dome light still work when you open the door?
Old 11-24-2018, 10:22 AM #8
No, sorry but the door ajar light is off and won’t bleed your battery
Old 11-25-2018, 08:39 AM #9
Full disclosure. I had to replace the rear hatch from a sonar vehicle due to impact damage. I messed with the striker adjusting for over an hour and wd40’d the hatch catch mechanism and when for the “done with this fix”. I will probably pull apart and solder the wire and wix right in the spring.
Old 11-25-2018, 08:39 AM #10
Donor
Rear hatch latch problem. Bearcat5150 3rd gen T4Rs 1 04-18-2018 03:55 PM
WTB: 3rd gen rear hatch latch fastolds Want to Buy/Trade 0 03-25-2018 01:54 PM
SIAP: Electric Latch on Rear Hatch (2004 Model) scrooster 4th Gen T4Rs 5 12-14-2012 11:00 PM
Wtb ASAP: rear hatch door latch/lock (automatic) Houmack Want to Buy/Trade 0 10-30-2012 05:43 PM
Rear hatch will not open (not latch related) Steve240 3rd gen T4Rs 5 09-14-2012 09:29 AM
