Hey Friends,
Questions about wheel bearings:
First, I'm pretty sure I have a bad wheel bearing in my front right wheel. It's making a jingling or higher pitched zerp-zerp-zerp sound that matches with the speed of the tires. Anyway I thought it was just bad tires but I recently bought new tires and I can hear it a little more clearly now. I took it back to the guys at Pep Boys to see if they concur with the bad wheel bearing theory, the mechanic walked out and pressed the tire around while the truck was still on the ground, he didn't really give me much info.
Anyway I also need to replace my lower ball joints soon, could the previous mentioned symptoms of vibrations and noise come from bad ball joints? The Pep boys guy said it could but that wouldn't make sense
, I assume bad LBJ's wouldn't exhibit those problems but I could be wrong.
Second, about wheel bearing replacements
From what I've gathered, some manufacturers or parts companies sell the whole assembly of the wheel bearing and hub (cutting out the need to press the bearing in and out). This is not the case with 3rd gen runner parts right? I ask this since it may be something I'd want to try and tackle myself and out of sheer convenience and laziness don't really want to try and find someone to press out the bearings.
