Old 08-20-2020, 02:41 PM #16
gordolven gordolven is offline
gordolven is on a distinguished road
Do you have any ideas or recommendations for installing this in Indianapolis, IN? Just moved here and developed the issue on my 08. Thank you-
gordolven is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 10:33 PM #17
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Does anybody here happen to have video of the roaring/vibration? I believe I might have it to a slight degree but not quite sure
Old 08-24-2020, 10:58 PM #18
Dom8706's Avatar
Dom8706 Dom8706 is offline
Dom8706 is on a distinguished road
Dom8706's Avatar
I dont have a video for you but if i recall correctly a way of checking to see if this is whats causing your vibration/roaring is to turn on your awd/4wd and if it is the clamshell the vibration/roaring should stop.
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
Dom8706 is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 11:33 PM #19
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Thanks for the tip! If ECGS didn't charge an arm and a leg for the tools to go with the bearing I'd be more keen to do it regardless
Old 08-24-2020, 11:50 PM #20
Dom8706's Avatar
Dom8706's Avatar
I still have the tool in question. Id be willing to give it to you you'd just have to pay for the shipping (couple bucks probably). Or i could make a little side trip and drop it off to you the next time i drive up to Bellingham. If you end up needed it.
Old 08-25-2020, 12:48 AM #21
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
That's very kind, i appreciate it, I'll have to wait and see if it's needed and get back to you
You make the trip up to BHam from Portland? Hot damn that's quite the haul. I go up every month or so to see some friends and that hour+ drive is more than enough for me
Old 08-25-2020, 12:51 AM #22
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Get under your truck and try to wiggle the driver side cv where it goes into the diff. IMO that’s a pretty clear indicator if it has a decent amount of play. Wiggle the passenger side cv where it connects to the diff for comparison.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 05:39 PM #23
JCruz JCruz is offline
JCruz will become famous soon enough
Im fairly sure I have this issue.
At 35ish MPH I get a loud noise from the front end and a vibration in the steering wheel. When I put it in 4wd it stops, then returns slowly when I put it back in 2wd.
I got under the truck and the CV axle is solid at the tire, loose enough to clunk at the diff on the drivers side, pass side is solid on both ends.
JCruz is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 11:11 PM #24
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Thanks for the offer but I'm fairly positive it was my driveline. Just replaced it today with a much better, slightly longer one brand new from Drivelines NW. So far it rides like glass again. Like the poster above my vibration started like a switch at 35mph but it wasn't affected by 4WD whatsoever, and my CVs had even amounts of play - or lack thereof, at lest - thanks for the advice guys, that was a great way to check, saved me doing an unnecessary job
Old 09-22-2020, 07:40 PM #25
For petes sake.
ECGS shipped me the puller tool, the seal, but forgot the bushing itself!
Guess i'm not doing this work over this weekend.
Old 09-23-2020, 01:21 PM #26
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Hey guys
Is this worth doing with only like a 1-1.5" lift?
Old 09-23-2020, 05:04 PM #27
T4topher's Avatar
T4topher's Avatar
Originally Posted by jross20 View Post
Hey guys
Only worth doing if you have the problem, wiggle your cv shafts where they connect into the front differential. If the driver side has a considerable amount of more play than the passenger side then it’s potentially worth doing.
Old 09-23-2020, 06:55 PM #28
jross20's Avatar
jross20's Avatar
Are we talking about axial play or longitudinal play?
(Left to right wiggle or in and out?
Old 09-23-2020, 07:00 PM #29
T4topher's Avatar
T4topher's Avatar
Up/down or left/right. Not in/out. It’s pretty obvious once you get your hands on your cv’s. My driver side had a significant amount of play compared to my passenger side. I’m pretty sure we demonstrated wiggling the cv’s in the video.
edit: it’s around 8 minutes into the video we do the demonstration of wiggling the cv.
Old 09-23-2020, 07:31 PM #30
jross20's Avatar
jross20's Avatar
Okay cool just wanted to make sure I knew what I was looking for. Does it need to be jacked up or have the weight off the wheels? Or does that not matter?
Nasty grinding in 4wd after ECGS bushing install Blobbins 3rd gen T4Rs 6 06-30-2019 01:49 AM
ECGS clamshell bushing headcount? JLRSR5 4th Gen T4Rs 9 06-06-2017 09:48 PM
Removal tool for installing ECGS 8" Clamshell Bushing Geerlijd For Sale: T4R Items 0 08-13-2016 06:46 AM
FS: 4.30 E-Locker, Axle housing, Matching front Clamshell - Las Vegas $500 Stocky3 For Sale: T4R Items 14 11-03-2014 02:52 PM
