Old 12-11-2018, 08:50 PM #1
Rwm514 Rwm514 is offline
Rwm514 is on a distinguished road
Help, creaking noise front end
I have been slowing replacing as much of the front end rubber on my 96 as possible but still have a noise up front. Not sure what it could be.
Previous owner lifted it with bilsteins and "tall" 99 springs right before I bought it. Within a couple months, some really loud groaning and creaking was happening mainly with braking at slow speeds or going over bumps. I replace the lower ball joints and outer tie rod ends. This did nothing to stop the noises. Next I replaced the lower control arm bushings and steering rack bushings. Amazing how disintegrated the LCA bushings were. This helped quite a bit but still had quite a bit of popping and creaking. A week ago I replaced the upper ball joints and upper control arm bushings. This really improved the ride and feel of the suspension and for a while seemed perfectly quiet. I was so happy. I thought I finally had done everything that I could but now a week later I am noticing some more creaky pops, not too loud but I want to figure out what it is.
It happens at slow speed when changing direction from L to R or R to L. Like it pops as the weight of the front end shifts from one side to the other.
Any ideas? The sway bar end links look to be in good shape as well as the sway bar bushings. I can't think of anything else I could replace.
Rwm514 is offline   Reply With QuoteReply With Quote
Old 12-11-2018, 09:27 PM #2
spartacus's Avatar
spartacus's Avatar
wouldn't hurt to check the inner tie rod ends.
Old 12-12-2018, 01:45 AM #3
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
My 4th gen does that L to R pop/tap when the cam bolts are not torqued properly...lower control arm.
Maybe recheck the bolts you have been playing with.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 12-12-2018, 09:06 AM #4
DaMonkey's Avatar
DaMonkey DaMonkey is offline
DaMonkey will become famous soon enough DaMonkey will become famous soon enough
DaMonkey's Avatar
Any poly bushings? Nice to have on sway bar (IMO) but can get squeaky AF
DaMonkey is offline   Reply With QuoteReply With Quote
Old 12-12-2018, 10:44 AM #5
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Tighten the "HELL" out of the LCA cambolts. With the front end of the truck off the ground, mark the cam graduations, then loosen the cam bolts a little. Lower the front end and tighten the bolts up. Make sure the LCAs are at the same settings before you tighten them. Doing one side at a time should eliminate any chance of movement. You can do the same to the UCAs (minus marking the cams of course)
Also, make sure the sway bar links are tight on the LCA. They may look tight but may move when weight is shifted. You could verify if this is the source by disconnecting the link at the swaybar and seeing if the noise goes away.
Don't forget the rear bushings either. If your front were bad then your rears may be in bad shape too.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 12-12-2018, 09:30 PM #6
Thx guys!
That helps. But god I hope it's not the lca cam bolts lol.
Those things are a nightmare.
I took it to a shop near my house to get it aligned and they said they had to torque them to 250 ft/lbs to get them tight. I used some pricey ones from Napa with a grease fitting.
I'll update once I get back under there. Kinda cold up here in Flagstaff but hopefully I'll be able to start working in my garage, I think I sold my sports car.
98 SR5 4X4
Creaking Noise Gesekee19 5th gen T4Rs 15 09-17-2017 03:31 AM
03 Sport Front Popping Clunking Creaking Noise? dalandshark 4th Gen T4Rs 8 03-24-2015 07:47 AM
4th gen Creaking Noise hufflite Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-06-2014 11:21 AM
creaking noise up front + vibration benedict1337 3rd gen T4Rs 17 02-24-2013 09:44 PM
Creaking noise in 04 Sport my04runner Problems & Warranty Issues 10 10-28-2004 01:04 PM
