Well I just got an oem Toyota fob from eBay for 15$ (per
infamousRNR
’s recommendation) and I just programmed it last night in 5 minutes. Worked flawlessly, even rolls the back window down. You must get the fob with the fcc Id HYQ12BBX. I can post the programming instructions as well if needed. Helpful hint if your door locks get weak after a few lock/unlocks then it’s better to just use your key in the door to do the unlock/lock cycles.
If you dont want a fob that looks used then just grab a case for the oem fob from AJT, looks awesome but a little pricey.
For reference I have a 2000 t4r
