12-14-2018, 12:18 AM
Real Name: Greg
Real Name: Greg
Question about modifying an Odyssey battery hold down kit
Visit the SURF RUNNER 2.0 Build Thread...
http://www.toyota-4runner.org/3rd-ge...mited-4wd.html
12-14-2018, 03:08 AM
Real Name: Keith
Real Name: Keith
The first photo shows the new batt hold down working fine w/o the plastic spacer. If the new battery hold down doesn't need the bottom spacer, what is the question?
Are you still planning to use the stock battery hold down to hold down the new custom battery hold down?
I accommodated the same PC 1500 34R battery similar to the way you did, except instead of cardboard, I added aluminum angle to the stock hold down cradle ears. Glued with epoxy. Dead solid. Still fine, going on 6 years.
12-14-2018, 07:24 AM
Real Name: Greg
Real Name: Greg
As we both mentioned, perhaps the Odyssey hold down kit makes the shorter battery height a non issue. Is the only reason Odyssey sells the 1” spacer to utilize battery holders intended for a taller OEM battery? If that is the only reason then a spacer is probably not needed. I’ll have to see how everything looks and fits after installation. I’m also not sure how easy it is going to be to attach the bottom plate to the surface where the plastic OEM battery tray normally rests.
12-14-2018, 12:44 PM
The hold down kit you showed there will completely replace the stock hold down. Just bolt it down to the battery tray.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
12-14-2018, 02:07 PM
Real Name: Scott
Real Name: Scott
This is how I secured my aftermarket battery tray. There are bolt holes just underneath the battery tray where there is a relay secured. You can fashion a bracket to bolt in there and then secure your tray to that.
12-14-2018, 03:49 PM
Real Name: Keith
Real Name: Keith
Yes, from the photo you provided, the Odyssey 'cage' does not require any additional spacers.
You'll have to improvise a way to attach the cage to the vehicle.
FWIW, here's my adaptation of the stock hold down:
12-14-2018, 06:04 PM
Real Name: Jerod
Real Name: Jerod
This. No need for a fancy battery holder or spacer. Just make sure the battery is tall enough to contact both sides of the stock tie down and crank it tight.
12-14-2018, 09:15 PM
Originally Posted by gamefreakgc
This. No need for a fancy battery holder.
Unless you actually wheel your rig. The stock hold down is a joke. It let's the battery slide around a lot. Since putting in my Ballistic Fab battery box I never have to worry about my battery going flying into my fan shroud. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
12-14-2018, 09:29 PM
Real Name: Jerod
Real Name: Jerod
My alternator is so big it can't go anywhere lol. I've been wheeling enough, although not on the Rubicon or anything nuts, and I've never had my battery move. I have a Optima red top and it's not the same size as the stock battery size either.
12-14-2018, 10:41 PM
I'm at 9 years on my Odyssey in my 08 5.7 Tundra 84k now. Had one in my 96 4Runner but have since pulled it for my Buggy. The AGM Bosch I replaced it with seems to be great so far.
" No one drinks beer because their thirsty"
12-15-2018, 12:29 AM
I wheeled plenty fine with an odyssey battery for years with nothing more than a scrap piece of wood as a spacer on the factory bracket. Then bought a welder and modified the factory bracket. Hasn’t gone anywhere.
FWIW - I’ve now had two of of odyssey batteries fail right around the 3 year mark. I’m now moving on to NorthStar
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
12-15-2018, 02:59 AM
Real Name: Keith
Real Name: Keith
Yes, for some 'wheeling' is brutally rough driving. Some even 'wheel' for entertainment.
I just use the vehicle to 'get there.'
My battery hasn't moved since I installed it in 2013. That's having travelled many (500?) hundreds miles of washboard roads and easily over a thousand on dirt/rocks/sand using the slightly modified stock hold down.
By the way, the two FJ-60 Landcruisers I had had a similar battery hold down.
Ahhh, the Landcruisers...they actually were professional grade.
01-20-2020, 05:06 PM
Which battery and box did you go with? I just checked their site, and they don't have one for the Odyssey PC 1500 34R.
02 4WD SR5 - (F) King CO w/Icon UCA, (R) King 2.5 w/ RR & Adj w/ OME 890, AOR front bumper, JTA custom sliders, Outgear roof rack, E-locker, Sequoia 5 stars, Duratrac's, Tundra 231 brakes, SS brake lines, custom sleeping platform/drawer system, fully wired Blue Sea Systems fuse block with Ripcord plate mod
01-20-2020, 08:57 PM
This one.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
01-22-2020, 02:00 AM
Oh, nice. Did you still use the Odyssey 34/78-PC1500DT and rewire the battery terminals, or does this cage also work with the PC 1500 34R?
