Old 01-05-2019, 02:40 AM #16
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Originally Posted by mtbtim View Post
I don't think the solenoid exposed to the elements is a big deal. I'll give you that the solenoid will block some air flow through the radiator but what blocks even more air is my CBI bumper. The OEM bumper has wind flow channels built into the lower part while my CBI bumper has solid plates. Looking at your Savage bumper with a winch installed, you'll probably have less air flow as well through the lower part of your radiator. My 98 with all the mods does run hotter than my 2000. But, my 98 is also carting around an extra 700 pounds all the time with the aftermarket bumpers, skid plates, rock rails and roof rack.
The aftermarket bumpers can be tradeoff in that respect. If one wants the virtues of such a bumper, I guess that comes with the territory. At least with the CBI and Savage offerings, which look somewhat similar, they have rather large openings, I'm sure to lighten them up, provide some access points, and also to permit some airflow... there might be an opportunity to channel or direct the flow, and I'll look into that later. I've gone so far as to "frame" a radiator a few years back, which allowed it to capture more air by preventing less spill-over, and forcing the air through the fins. Data logging showed that it worked pretty well...
The factory horns block air flow, up on top of course. Nothing of significance I imagine, but a little here, a little there... Adding another heat exchanger in front is detrimental to the radiator's job. The ambient air passing through the tranny cooler comes-out the back a bit warmer, then that goes through the condenser, and if that is operating, what then hits the radiator fins is markedly warmer than ambient, obviously impacting the delta we'd see otherwise. That's what happens when stacking heat exchangers though; and why sometimes it's beneficial to place one elsewhere... Fun stuff.
Back to winch talk! I have one coming Tuesday.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 02:47 AM #17
thenightman's Avatar
thenightman thenightman is offline
Real Name: keith and jenny
thenightman will become famous soon enough
Shit, cut that stupid Toyota grill so the solenoid fits. That's what I did to fit a Warn M8000 winch on my CBI Hybrid bumper. I guess if you have a fancy pants Satoshi grill you might think I'm nuts to suggest cutting into something so important. I think the Satoshi grill adds what, 30hp?
Maybe I'm weird but I actually like the look of the solenoid notched into the grill. I'm also a Function over Form kind of guy. Function is way more important than looks. Some people will spend money on a lift and new tires before they even take a look at the mechanical health of the vehicle.
Anyways, I'll get off my soapbox now. Happy Modding!
This, 100%. With all the modding people do to their 3rd gens, it kinda blows my mind that trimming the grill is out of the question for some. My whole plan is to cut away as much as possible to get the winch as close as possible. Smittybuilt 10k. I have no idea how long the solenoid wires are, it's been in storage for almost three years now.
Build thread
http://www.toyota-4runner.org/3rd-ge...ncemobile.html
Few dollars, and fewer sense
thenightman is offline   Reply With QuoteReply With Quote
Old 01-14-2019, 05:10 PM #18
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by TonyB66 View Post
Thanks for chiming-in. I think SB provides 5' of cable. Not sure where I read or heard that though... I'll look for spots behind the grille too. I'll be installing a transmission cooler there soon though so space will be more limited.
I've bookmarked some good discussions on dual batteries and increased output alternators. Glad you brought that up as I should revisit that again. Thanks.
Here's a picture of where I located the winch solenoid behind the front aftermarket bumper (4xInnovations). I've got it wrapped up in electrical tape for "weatherproofing" and am planning on welding up some sort of enclosure. There's plenty of room here for it:
weekendclimber is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 01:44 PM #19
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
Originally Posted by octanejunkie View Post
I have the same winch and an ARB
I've been wrestling with where to install the solenoid given how short the supplied cables are... pics would be awesome.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 09:40 PM #20
TonyB66's Avatar
TonyB66's Avatar
Originally Posted by rkntoy View Post
Appreciate you remembering.
The X2O one will fit there too. That said, I was envisioning fog lights in those spots. Hmmm... Maybe I'll put it in the engine bay.
Thanks again.
Old 01-20-2019, 12:57 AM #21
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Little of topic. But today cop pulled me over for tinted windows and no front license plates. After I drove pass a cop couple miles before lol. Anyways, I just ordered this.
Cascadia 4x4 | Off-Road | Winch Accessories Made In Canada/USA
For anyone looking to mount their plates back. They even sell one with a light bar option.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 01:21 AM #22
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Damn, that's pricey. I've had one of these on since I put my bumper on. Plus I still have a bunch of beer money left over.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 02:40 AM #23
TonyB66's Avatar
TonyB66's Avatar
Good stuff, thanks for sharing. 23 bucks, hard to pass on that...
Old 01-20-2019, 03:45 AM #24
psraff's Avatar
psraff psraff is offline
psraff is on a distinguished road
psraff's Avatar
As for relocating the solenoid, I had fun doing mine. It really wasn't hard. Plus you can install switches in the cab to operate the winch as well, if you want.
Really, cable isn't that expensive, and you can install the lugs on it yourself with a cheap hammer "press".
Post from my build thread: https://www.toyota-4runner.org/2815688-post149.html
Use this with a 5lb sledge for the lugs: Here.
AK to AZYota's '99 Build Thread
psraff is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 12:02 PM #25
TonyB66's Avatar
TonyB66's Avatar
psraff good to hear from you. Haven't seen you around much lately... Thanks for chiming-in and for sharing your switch install.
The unit I ordered comes with a wireless remote, but unfortunately that seems to be the primary knock on it, from the reviews I read. As I recall it's because the battery drains easily, so users have to remove the remote's battery, or something like that... It can also operate wired, so maybe I'll use it that way. I find your solution very appealing though.
Old 01-29-2019, 05:33 PM #26
psraff's Avatar
psraff's Avatar
You welcome. You're right, I did drift away from this for a bit. I haven't worked on my trailer either... What I have been doing is remodeling my house. Removing baseboard heat, putting in in-floor heat, new floors, paint, trim, interior doors, a few extras here and there. I actually have the flooring guy here today doing the last bedroom and hallway (only thing I won't do myself. It's more cost effective for me to have someone install the floor). All this to raise the appraisal value and hope to move out of Alaska this year.
Old 01-29-2019, 11:06 PM #27
TonyB66's Avatar
TonyB66's Avatar
I hear ya and know about house remodels, that's for damn sure. From 2012 to 2014 I busted my ass getting our old canyon home ready for the mkt and sold. Bought a new place before that sale, a fixer-up of course, and worked on both for a good part of a year (homes about 20 minutes apart), until I worked myself into the hospital. That slowed me down, lol. The last few years, working on the "new" place, which is like 95% done... I so look-forward to working on the 4Runner for a change of pace.
Best to you on getting a desirable sale; while not jeopardizing your health!
Old 02-01-2019, 12:16 AM #28
psraff's Avatar
psraff's Avatar
Thanks! All of this to try to move down to your neck of the woods (Arizona most likely). Seems like every day Alaska is getting under my skin more and more. For instance today. I went to Fastenal for the nuts for the O2 sensors (I found a thread that had a link to their page showing the exact nut I needed). Their answer was. "Oh no, that's not a popular nut. And metric. No we don't carry that. Closest place that has it is in California." I can't even get a fricking Stainless Steel metric nut with the Flange on it up here without trying a dozen places!!!
Yes I know we've strayed off topic a bit.... LOL
Old 02-01-2019, 01:12 AM #29
TonyB66's Avatar
TonyB66's Avatar
Alaska to Arizona, wow! That's a damn radical change. Arizona has my interest too actually, areas with some elevation though (less heat).
To help get this back on the track, I got this a couple weeks back...
Old 08-11-2019, 10:56 AM #30
TonyB66's Avatar
TonyB66's Avatar
Just re-found this thread while searching for other stuff like winch covers...
As a matter of closure, I got it installed recently.
With respect to the control box, the side mount option was not feasible with the Savage bumper and at the top, I was not keen on blocking yet more precious airflow, I stuck it inside the bumper as rkntoy showed earlier, but in a different orientation to allow for lighting (Baja Designs Squadrons. wide cornering).
Now back to finding a cover! Oh, and I think I'll get that flip-able license plate holder Matt referenced earlier...
bumper , front , savage , winch , winches
Installed fog lights on SAVAGE front bumper :) kolelt 3rd gen T4Rs 0 12-24-2017 09:50 PM
New savage front bumper install dhalsey 3rd gen T4Rs 47 04-22-2015 07:47 AM
Savage OffRoad new front bumper masson74 3rd gen T4Rs 10 07-24-2014 10:58 PM
Anyone with a Savage Offroad front bumper? 4Runner93 3rd gen T4Rs 15 10-01-2010 02:55 AM
