Old 01-05-2019, 02:06 PM #1
Rio Bravo Rio Bravo is offline
Rio Bravo is on a distinguished road
Homemade flat full length roof rack
Hey guys, new to the forum but a long time lurker. I thought it was time I contribute something. I've taken advantage of all the info on here for long enough.
Without further ado. I began with factory rails that I bought on ebay. My 4Runner didn't have a factory roof rack, it just had the little plastic runner things. The factory rails bolted right in and haven't been a problem at all.
Homemade flat full length roof rack-img_0477-jpg
The factory rails come with 3 channel nuts. I want to say that they are M6, but I'm not 100%. I can check on that later. I ended up using another channel nut that I took off the factory cross rail and inserted. I used 2 bolts on each L bracket to secure it to the factory rail. (Hence the need for 4 channel nuts).
Homemade flat full length roof rack-img_0487-jpg
Rio Bravo is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 02:17 PM #2
Here is a look at the brackets. I used 1.25 inch angle iron. The roof is not flat, so we had to angle the upright part of the bracket in slightly. It is an inexact science, and I used a grinder, a level, and soap stone to get the bottom angled somewhat correctly. Basically, I would put the upright on the angle iron on the factory rail and use the level to see how much to grind off the upright. I went little by little, and eventually got close.
Homemade flat full length roof rack-img_0490-jpg
Here is a look at the pedestal I put on top of the upright. This bracket is on the back of the roof rack. I would have done all 4 brackets like this, but my flooring dictated that I do something different on the front bracket. That being said I think the pedestal mount is the way to go.
Homemade flat full length roof rack-img_0489-jpg
This is what the rack itself looks like. It is a flat rack, and the bottom is some industrial shelving. The edge of the rack is 1.25 inch square tubing that I found in a dumpster. It was already bent at 90 in a square, so all I did was lengthen it and make it a little narrower. It is 86 inches x 41 inches.
Homemade flat full length roof rack-img_0491-jpg
Old 01-05-2019, 03:07 PM #3
Rancho5 Rancho5 is offline
Rancho5 is on a distinguished road
Looking good!
02 Thundercloud Sport, 155k.
Rancho5 is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 03:46 PM #4
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy will become famous soon enough Wedgy will become famous soon enough
Wedgy's Avatar
Pretty stout looking rack, and cheap too !
I extended my factory rack by adding ~27" of channel towards the front to give it more support when carrying a kayak.
Toyota 4Runner Forum - Largest 4Runner Forum - View Single Post - What did you do to your 3rd gen today?
Homemade flat full length roof rack-thumbnail%20-18-jpg  Homemade flat full length roof rack-thumbnail%20-14-1-jpg
Wedgy is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 01:30 AM #5
Thanks for the compliments guys. That's really interesting with the extended rails.
How did you attach it to the roof? Did the downward angle towards the front mess anything up?
Old 01-06-2019, 01:33 AM #6
Wedgy just followed your link and answered my own questions lol. Still a noob.
Any leaks or problems drilling into the roof?
Old 01-07-2019, 05:46 PM #7
Here's a look at how I mounted the rack to the brackets and the roof. This is the rear bracket. It's basically a pedestal bolted to the angle iron supporting the floor of the rack.
Homemade flat full length roof rack-img_0503-jpg
The middle bracket was different from the rear bracket because of how my flooring ended up. I used an industrial shelf and there were metal runners welded to the mesh that I used to weld to the frame of the rack. The way that it spaced out meant that for the middle bracket I had to secure it directly to the frame and not to the floor. I ended up drilling through the frame to the upright on the L bracket which I extended to flush with the top of the frame. I am going to fill the hole in with some spray foam later to keep out water.
Homemade flat full length roof rack-img_0500-jpg
Homemade flat full length roof rack-img_0501-jpg
Finally, here is what I did up front. I used solid square tubing and strapping to make a base. Same story as before: inexact science, used grinder, and soap stone to figure out the angle. Underneath it is some 3M grip tape/cushioning I found at the hardware store.
Homemade flat full length roof rack-img_0504-jpg
Homemade flat full length roof rack-img_0506-jpg
Old 01-07-2019, 05:54 PM #8
It turned out pretty well and I like the design of the flat rack. It's very functional, and is strong enough to walk on. I can put lumber on top of it and haul around my wooden pirogue. There is a little wind noise at high speed but it isn't bad. It's sort of the same sound as driving an aggressive tire at highway speed, but it isn't as loud.
It is a little higher in the front than I would prefer, but it doesn't bother me that much. I made the rear brackets to be 2 inches above the factory rails which might be a little high. In hindsight, I think an inch and a half would be just about right.
Homemade flat full length roof rack-img_0492-jpg
Homemade flat full length roof rack-img_0494-jpg
Homemade flat full length roof rack-img_0493-jpg
Old 01-07-2019, 09:11 PM #9
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
Nice to see someone else build their own roof rack. I built my first rack and it served me very well. There is a good bit of price in having something built, not bought.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 01-09-2019, 12:21 AM #10
There really is, and it's nice to able to modify it exactly for what you need it for.
channel , factory , rail , rails , time
Front Runner full length roof rack. First production run rack install. Apex Overland 5th gen T4Rs 59 06-04-2017 08:47 PM
Baja Rack full length flat rack. AZBub 3rd gen T4Rs 6 09-19-2016 05:34 PM
Full length factory roof rail/Aluminum Roof Rack FreshSeabass 3rd gen T4Rs 2 09-06-2016 10:07 PM
FULL LENGTH 3rd Gen Roof Rack Whitson Metalworks For Sale: T4R Items 16 10-06-2012 05:45 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
