Old 01-25-2019, 06:14 PM #16
Atomic6's Avatar
Atomic6 Atomic6 is offline
Real Name: Tim
Atomic6 will become famous soon enough
Atomic6's Avatar
Real Name: Tim
For some reason I wasn't getting notification on this thread. Sorry guys!
Originally Posted by nissanh View Post
Don't do a water crossing as the joints are not 100% sealed.
Snorkels aren't just for water crossings. Higher intake and out of the wheel wells = less dust ingestion. Last time I was in Moab, I was the only one without a snorkel and had to swap to a new filter since the other one was covered in dust after two days on the Kokopelli. To this day, I'm still cleaning out dirt/dust from every crevice of the truck. The joints in this snorkel are 100% sealed, its the stock joints that are a problem.
Originally Posted by RunningForNow View Post
Looks great, and a great write up. I’ve been thinking about getting one as well, but I would look like a poser, as I will never ford water so deep that I would need a snorkel.
Originally Posted by Yoter View Post
It is out of stock now but I might give it a try when they get more, doing this 100% for poser, mall crawler looks, I never drive through deep water
Aren't we all poser a little?
Originally Posted by kolelt View Post
That looks good. I would not drill holes into the a-pillar. When I did my snorkel. I used a zip tie to hold the snorkel to the light bar mount. And double sided tape. A pillar is small, and if it ever rust out from the holes. That’s a shot spot to fix.
If you've read my build thread you'd know a few more holes don't matter to me.
Originally Posted by JWaldz View Post
Can't believe more people haven't jumped on this snorkel.
I went ahead and bought it since it seems like every time they get more in stock, they bump up the price. Thanks for posting the install.
@Atomic6 Do you think removing the fender is required? Some on TW mention that the upper mount of the snorkel is basically impossible to get to if you don't. Albeit, only 2 may all be that's needed to secure it to the fender. Also, was the antenna in the way? I have a power antenna so I'm thinking the motor will be in the way, which may require removal of the fender anyways. TW guys also state removing the fender flare to access the inner fender splash guards. I haven't looked under my fender specifically for this reason, but is this required for us?
Seriously @JWaldz , with how popular the other snorkel is, I can't believe more people aren't jumping on this one. Maybe the majority of pro-snorkel guys already installed the 167 one?
I don't think you'd have to remove the fender. It definitely made it much easier though. You'd probably be able to hammer the lip of metal away, but the power antenna motor might be in your way of doing this already. There is clearance for the antenna on the outside of the snorkel. Yeah, like the TW guys said, the top bolt is impossible to install without removing the fender. You won't need to take your flare off to install.
Originally Posted by apohl17 View Post
OP, awesome little writeup and clear documentation. Most guys I've seen on here install the snorkel without removing the fender- did you have to in order to hammer down that metal lip that was in the way? Or did it just make it easier...? Thanks
You'd probably be able to do the complete install with the fender on. You won't be able to tighten the top bolt, but most Tacoma guys are running without the bolt without problems. I mainly took off the fender since I haven't seen this one on another 4Runner. It was easier to make sure everything was lined up and I didn't have anything else in the way.
Build Thread
KE0MYV
1998 4Runner SR5 4x4
Atomic6 is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 06:26 PM #17
Atomic6's Avatar
Real Name: Tim
Atomic6's Avatar
Real Name: Tim
Few more photos after a much needed wash:
Build Thread
KE0MYV
Old 01-25-2019, 07:23 PM #18
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
I have the same color runner so it's nice to see what it would look like...I dig the straight up the side and not from the front, the YO sticker hits the spot, I put them on my order list and hopefully the price goes back to that price you ..the got!! That roll bar too, sweet.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 09:25 PM #19
Atomic6's Avatar
Real Name: Tim
Atomic6's Avatar
Real Name: Tim
Thanks! Finishing the roll bar is next on the mod list. The YO is from an old Toyota Pickup I found in the junkyard. It's just a place holder to check sizing. I'm chatting with @hoksibish about 3D printing something different.
Build Thread
KE0MYV
Old 01-26-2019, 12:06 AM #20
hoksibish hoksibish is offline
hoksibish is on a distinguished road
Looking forward to it. Should be a nice add-on!
hoksibish is offline   Reply With QuoteReply With Quote
Old 01-26-2019, 03:11 AM #21
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
That periscope at the top can't be good for mpg (not a criticism of this one since they are all like that). I'd probably mod it to something more flush up there, and facing backwards. I've heard the argument that facing forward helps with ramming the air into it at higher pressure but I'm somewhat skeptical.
Maybe use this with the deck plate mod and keep both open until you really need the snorkel then just close the deck plate.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 05:21 AM #22
Jaketino's Avatar
Jaketino Jaketino is offline
Real Name: Brandon Hutchens
Jaketino is on a distinguished road
Jaketino's Avatar
I've been watching this since it originally went up here, the price seems to keep going up with every shipment they sell out of. Last thing I knew, they were sold out for $130 up from $120 the week before; as of now they have 2 left at $150. Soon they'll be ARB prices.
'98 Limited auto w/ factory locker 217k
ROLA roof rack with custom low profile mounts+LED lightbar, Procomp Lights on bumper, 265/75/16 Goodyear Duratracs, Finally lifted with Fabtech FTS2200 coilovers and LC 8 wraps/Tokico LC shocks
Changing rear coils to OME 861's soon because of my new NWTI rear bumper
Jaketino is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 04:51 PM #23
Yoter's Avatar
Yoter Yoter is offline
Yoter will become famous soon enough
Yoter's Avatar
Yeah, they wont take an offer either. I tried offering them 129.00 and they refused. Once we stop buying them, the prices will probably drop again.
2000 "The Silver Legacy 2" Highlander Edition, 5speed 4x4
2000 "The Silver Legacy" Highlander Edition, 5speed 4x4 RIP
1996 Stellar Blue 5 Speed Sold
Yoter is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 11:20 AM #24
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I know this will sound a little crazy but...
once this is bolted on? does this mean no more gas station car wash machine spinning wheel flappy wash jobs?
I would guess it would get messed up or break the wash machine. don't want to get water down the pipe.
Old 01-28-2019, 12:30 PM #25
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
Most car washes typically have a warning about if you have any external 'non factory' parts on your vehicle they can be damaged or even damage the car wash equipment. This goes for brushless and brushed washes. I haven't used a drive through car wash in years for this reason. I have way too many things "hanging" off my truck.
Even if you a completely stock vehicle and just this snorkel, I wouldn't suggest using the drive through.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 12:47 PM #26
JVC8790's Avatar
JVC8790 JVC8790 is offline
Real Name: John
JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about
JVC8790's Avatar
Real Name: John
You can always look for a touchless wash. Luckily there is one near my work that's only $6 and has no brushes bristles, it has a spray bar that works its way around the parked car. Admittedly it probably doesn't get off as much dirt as the brushes would if your car was significantly dirty but it does a good job for maintenance washes in between hand washes.
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
JVC8790 is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 03:55 PM #27
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
I'd be interested in seeing what you guys come up with for the spot. I was thinking of some kind of oval shaped TRD logo that you can just 3M on. If you google "Oval TRD emblem" you can kind of get an idea.
Out of curiosity, what's the width and length of the oval shape on the snorkel?
Old 01-28-2019, 06:00 PM #28
DreadPirateJon's Avatar
DreadPirateJon DreadPirateJon is offline
DreadPirateJon is on a distinguished road
I just grabbed one of these. With it constantly going up in price seemed like a good idea just to grab it for when I eventually have need for it.
97 5spd with elocker
Build Thread https://www.toyota-4runner.org/3rd-g...st-bucket.html
2 inch Lift (Bilstein 5100 F&R, 99 Talls F, OME R), 33 Inch Tires
Rebuilt Engine, Doug Thorley Headers, Gibson Catback
DreadPirateJon is offline   Reply With QuoteReply With Quote
Old 01-29-2019, 10:59 AM #29
Atomic6's Avatar
Real Name: Tim
Atomic6's Avatar
Real Name: Tim
That's exactly the plan: an oval TRD, TEQ, or TOYOTA logo. The TRD seems like the best shape since the "R" fills out the oval nicely. The oval shape is ~2-5/8" x 1-3/8"
Build Thread
KE0MYV
Old 01-29-2019, 11:36 AM #30
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
Thanks! This is the best thing I can find for it online. I also like that it's resin. It's just a tad shy of the opening but would fit it pretty nicely. However, it's unavailable and I can't find it anywhere else online.
a-pillar , intake , it’s , snorkel , template
Safari snorkel on a 5th gen? iRide4Runner 5th gen T4Rs 1273 04-21-2021 03:32 PM
Safari Snorkel confirms snorkel for 4th-gen coming 4WDToyotaOwnerMag 4th Gen T4Rs 488 11-01-2020 10:46 PM
Safari Snorkel releasing snorkel for 3rd-gen 4Runners 4WDToyotaOwnerMag 3rd gen T4Rs 127 03-28-2020 07:56 PM
CA: Safari Snorkel 5TH Gen DEMIK For Sale: T4R Items 5 09-28-2017 05:49 AM
Safari Snorkel on a 5th Gen? 2010 4Runner ATX 5th gen T4Rs 7 08-17-2016 04:09 PM
