Old 04-02-2019, 02:32 PM #61
thegipper's Avatar
thegipper thegipper is offline
thegipper will become famous soon enough thegipper will become famous soon enough
thegipper's Avatar
You can use the portion of Tim/Sean's valve cover gasket replacement video that pertains to the intake removal.
YouTube
It really isn't hard at all, shouldn't take you more than a couple hours total to swap the harness over. If you get stumped, we'll help.
Good luck
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 03:05 PM #62
96RedRunner has a spectacular aura about 96RedRunner has a spectacular aura about
I like taking pictures on a job that gets this deep.
Old 04-02-2019, 03:39 PM #63
phattyduck is a name known to all phattyduck is a name known to all phattyduck is a name known to all phattyduck is a name known to all phattyduck is a name known to all phattyduck is a name known to all
The transmission portion of the harness is the hardest, just due to access and dirt in the connectors. Make sure you get the ADD plug down below the driver side exhaust manifold.
I would suggest pulling the harness from the inside and transmission, laying them over the engine and removing the engine. Once both engines are side by side, swapping anything necessary will be much easier.
'16 Honda Odyssey
Old 04-02-2019, 04:15 PM #64
SaulG's Avatar
SaulG SaulG is offline
SaulG is on a distinguished road
SaulG's Avatar
Don't make it harder for yourself than needed, Mark hood hinges and get that off and out of the way.
2) Pull battery and Air box,Radiator all in big pieces
3) Pull air plenums upper/lower .. reuse your old ones ( pull new engines on stand ) mindfull of knock sensors etc etc
4)Remove engine harness from engine and tuck under wiper arms. Pull starter and motor mount bolts..trans bolts exhaust nuts
5) support trans at highest angle ..pull
SaulG is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 06:24 PM #65
RuggedRunner's Avatar
RuggedRunner RuggedRunner is offline
RuggedRunner is on a distinguished road
Thanks guys, I got the manual wiring harness on the new engine. It wasn't bad at all, I just took my time and made sure I didn't miss any plugs. I also got the spark plugs on too. I actually got the engine out yesterday without breaking anything or hurting myself, and put the flywheel/pilot bearing on, pcv valve/grommet, throttle body, oil cooler hoses and rear main seal. Now I just have to wait for the new engine mounts and oil cooler O ring. Can't wait to drive my truck again!
'99 5 speed 4x4 V6, OME/5100 lift, 32" ATs, Lots of maintenance and cheap mods
Engine replaced with '00 junkyard engine. 204k miles on body, 117k on engine
RuggedRunner is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 06:51 PM #66
JWaldz's Avatar
JWaldz JWaldz is online now
Moderator
Real Name: Waldo
JWaldz has a spectacular aura about JWaldz has a spectacular aura about JWaldz has a spectacular aura about
MY GARAGE
Moderator
JWaldz's Avatar
Real Name: Waldo
MY GARAGE
Word of advice on the harness.. Make sure the harness is attached to all the mounting locations. If some of them are broken, just zip tie the harness out of the way of moving parts. I missed a location near my transfer case drive shaft and it ended up getting snagged somehow, yanked the harness a little, and sheared the plug that went to my front diff actuator, separating the connector (fun fix).
3.4l are so easy to swap otherwise LOL!
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | RMRacks | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is online now   Reply With QuoteReply With Quote
Old 04-07-2019, 04:12 PM #67
Update:
After pulling the timing belt cover I realized that the timing belt had probably never been changed...looked pretty bad so I changed it yesterday along with the WP, pulleys and tensioner. Now if i could just mate the engine to the dang tranny...I was wrestling it for a few hours last night but couldn't get it lined up but hopefully i'll get it today.
Also while i was extending/replacing the front diff breather, I figured out why my 4wd isn't working! I was a little depressed last time i went wheeling and realized the front wheels weren't turning. Make sure these vacuum lines aren't touching the header or they will melt!!!
Did my engine just blow up? help.-img_1087-jpg  Did my engine just blow up? help.-img_1095-jpg
Old 04-07-2019, 04:23 PM #68
Ahh, much better. I'm wondering why I didn't replace these before. 20 year old vacuum hose is fragile.
Did my engine just blow up? help.-screen-shot-2019-04-07-4-11-52-pm-jpg
Old 04-07-2019, 09:30 PM #69
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice
Real Name: Jerod
A friend helped me and we ended up taking some ratchet straps and help level it out. It wants to tilt and the fan is looking up in the sky correct? Take one end of the ratchet and put it on the back of the manifold or something similar, then connect it to the ring at the top of lift. We used two, one on each side and was able to level off the engine enough to bolt it up. Definitely not a one person job.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 04-08-2019, 11:46 AM #70
Thanks, I got it in about an hour and a half yesterday by my self. i used the ratchet strap trick and i twisted the rear driveshaft a few times and it went right in.
Old 04-13-2019, 01:01 AM #71
Thanks for everyones help. Got the engine fired up 4 days ago and it's running great! It seems to run better than the old engine.
change , engine , miles , smoke , time
$500-$600 to blow Shoey 4th Gen T4Rs 7 12-19-2014 06:18 AM
Help Me Blow $1,000! Kanger328 3rd gen T4Rs 18 02-09-2013 03:15 PM
No Blow phryque 4th Gen T4Rs 4 06-17-2012 12:35 PM
Blow and Go? markopolo 3rd gen T4Rs 11 11-07-2011 11:17 AM
Wanna see Acura RSX-S Engine Blow?! Thai Off Topic 3 06-06-2003 11:38 PM
Copyright © 2019
