Originally Posted by T4topher
I’d check this, the two halves of the plastic ball are what had play in my steering column.. Watch Timmy the Toolman video on steering column fix, we do it on my truck. Just cut out a piece of an old oil bottle to fit between the two halves of plastic.
Edit: if you haven’t already check the outter tie rods as well for peace of mind..
Circling back to close the loop on this thread. I took my column apart again this weekend (I had already welded the slip joint previously) and put a spacer in between the two balls of tilt mechanism as
T4topher
suggested. Put everything back together and the play I had is 100% eliminated. The steering is the tightest it has ever felt.
Very happy since I've been fighting this ever since I bought the truck and the slip joint was loose. Fingers crossed I never have to pull the column out and mess with it again!
