Originally Posted by kolelt
Thanks. This is what it looks like from behind. I'm down on the ground taking this pic. When standing up they are not noticeable. I modified my exhaust after I lifted so they are not close to my tail pipe. I can get another pic later if you need
This is from the side (obviously, ha) and again I am close to ground when I took this pic.
First I cut out the spare tire cross member completely.
Then, I used some scrap 3" x 1/8" (I don't remember the length, I can measure if needed) flat steel and welded it to the truck as pictured. Then I cut and welded 2 pcs as sketched (in last pic). I welded them to the first piece and drilled holes and bolted the end closest to the bumper into factory tapped holes. Then I drilled and bolted the rotopax 'brackets' to them.
I hope that makes sense. If you need more pics, (now that I know how to upload them) or more info, let me know
Good luck
Durwin
