Originally Posted by T4R2014
Where's that bracket? I need to check this. I've had this hard, delayed shift issue since I got this truck. My high school aged judgement back then thought it was smart to tighten the cable when the truck was already shifting fine. It never shifted quite like it did even after I loosened the cable back. From then on, I NEVER touched the cable adjustment in my other 4Runners unless I felt something was genuinely wrong.
That thread seriously needs a disclaimer because noobs don't necessarily know what a properly adjusted cable should be like.
I'll upload a photo on where to look when I get home. I can't take a photo of the cable clamp though since it's very awkwardly on top of the bell housing.
Edit: Here's the photos. The first is the clamp on top of the bell housing (top left):
The second is the bracket that broke on me where it enters the transmission case. Not that the cable should be perfectly vertical, mine is obviously not since it's broken:
