01-17-2019, 01:19 PM
#16
Originally Posted by 96RedRunner
Yep thats right. Saturated gas goes in top of condensor liquid out bottom.
There will be liquid there, thats also a high side line with the most thermal expansion and contraction.
I'd braze it on the bench since it's a one shot deal.
If AC is working now recover/filter whats in system replace line pull vacumm
check for leaks charge with a bit of PAG oil and seal conditioner leak dye.
The freon is what drives up the cost.
Or just leave it alone since it isn't leaking?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-17-2019, 01:37 PM
#17
I learned that pesky fact about liquid in a pipe while trying to solder a fitting on copper house plumbing. If there is any water at all in the tube, it is impossible to get the metal hot enough to solder or braze it. I burned through a few propane canisters, before I learned that you must get all of the liquid out of the working area.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
01-17-2019, 01:41 PM
#18
Real Name: Mark
Real Name: Mark
True dat, but if you get a highside leak that big you lose all freon real quick plus most of PAG, his money.
I live in the south so AC high priority.
Be a good time to change drier, if drier desecant cartridge breaks apart gets into system your f..kd
Driers do have a life span, cost me $1200 how I know.
01-17-2019, 01:45 PM
#19
Real Name: Mark
Real Name: Mark
Yep I've gone as far as shoving bread into pipe to plug it to make joint with house plumbing.
01-17-2019, 01:46 PM
#20
You gotta be real good to braze aluminium, real good. Being that system is pressurized even when not running it's going to blow out right about the time
it goes molten to bond.
Afaik when brazing, you don't actually melt the surface, just the filler. Seems like the problem with brazing that line is the thin walls and the low specific heat of aluminium means it would be easy to blow through, especially if you are using something as indiscriminate as a gas torch.
So, reckon I can TIG braze it on the car? I maybe could crank the TIG heat up enough to get it hot without really heating up much of the liquid. Failing that, I can just bribe my welding teacher to braze it. But thats a bit silly, since I don't even think its leaking, so I will probably leave it until it explodes int he summer heat or something.
2000 SR5 - Build Thread
01-17-2019, 01:52 PM
#21
Correct. With brazing, the base metal may be near its melting temperature (such as with aluminum), but it's not supposed to actually melt, like it does with welding. That would be tricky and risky with thin aluminum tube. Too hot, and you ruin the entire thing. You really don't get much warning when aluminum melts. It doesn't turn red like steel. I wouldn't risk it, myself.
I don't have any personal experience with TIG. I wish I did - wish I could afford one of those very expensive machines. Then I would learn how to use it, because that could come in very, very handy on a lot of things.
01-17-2019, 01:54 PM
#22
I would definitely evacuate the system.
01-17-2019, 02:03 PM
#23
No point in doing that now, all the sites about recharging AC says not to do it below 50-60 degrees or so. Its not gonna get that warm here for another 2-3 months at least (unless I drive down to the border lol.) So I guess, the only thing I can do for now is to hope it doesn't leak.
01-17-2019, 02:28 PM
#24
Real Name: Mark
Real Name: Mark
Afaik when brazing, you don't actually melt the surface, just the filler..
True to a point, you have to get base material to that fine line so filler bonds,
Aluminum is hard to see that fine line before it goes molten.
01-17-2019, 02:31 PM
#25
Yea, I spent a few years in high school welding aluminium robot frames for some competitions. Its was a fast learning experience, especially when you eventually figure out you're using 75/25 gas instead of argon. But I've never brazed it before.
01-17-2019, 02:56 PM
#26
If you *are* going to fix it, just get a 'new line' from a junkyard truck. And new o-rings, and a new drier, and the time and effort to evacuate, replace parts, vacuum, test for leaks, then refill.
*or*
You could just leave the damn thing.
It maxes out below 400PSI and won't damage anything if it leaks... This is not a power steering or fuel line near your exhaust or something.
01-17-2019, 02:57 PM
#27
Real Name: Mark
Real Name: Mark
Another thing about aluminum is it doesn't like impurities when welding/brazing.
Plastic bristle brush only, dirt is a problem, oil will boil off and pop a hole.
Be good learning experience however you go about. First for me was couple yrs after highschool
1978 using Tig with argon. Aluminum is not a forgiving type of material to work with when it's thin, Tig and SS is my favorite.
12-17-2020, 11:50 AM
#28
Real Name: Patrick
Real Name: Patrick
Originally Posted by KylieHodges
Hi guys, I understand that this thread is quite old, but I would like to give my husband an angle grinder. He dreamed about it but I really think that it is dangerous for home use, especially if you don't have any experience. What do you think about that?
As long as you take the guard off and use one of the blades: https://www.homedepot.com/p/King-Art...E&gclsrc=aw.ds I think it's perfectly safe!
12-17-2020, 11:56 AM
#29
Real Name: Scott
Real Name: Scott
No offense, but the only thing you have to ask yourself is "Is my husband an idiot?" If the answer is no, then using an angle grinder at home is just fine. Get him some breathing and eye protection while you're at it too.
12-17-2020, 01:12 PM
#30
Only one way to get experience.
So long as eyes and ears are protected, worst he can do it get a nasty scar.
Not at all as dangerous as a chainsaw, where even if you do have the proper PPE, its easy for an idiot to chop off a hand (coming from the idiot who nearly cut his leg off with a chainsaw.)
