Old 01-16-2019, 03:48 PM #1
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
Nicked radiator hard line with angle grinder
While cutting my frame endcaps off the put a bumper on, bumblefinger me nicked one of my radiator hard lines with a cutoff wheel. Its seems to be at least 1/2mm deep. Should I immediately replace this line, or can I just JB weld it a bit and replace it with my radiator in the next few months? Alternatively, can I just slap a tack on there (assuming the line is steel) with my mig, or is the risk of burning through too high?
Pic:
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 03:54 PM #2
That's an AC line, made of aluminum. Leave it alone unless it starts to leak...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-16-2019, 03:57 PM #3
Can I still JB weld it hopefully to reduce the risk of it cracking there?
Old 01-16-2019, 04:11 PM #4
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Don't see why not.
APhelps is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 04:13 PM #5
cfranck1's Avatar
cfranck1 cfranck1 is offline
cfranck1 is on a distinguished road
cfranck1's Avatar
Sure why not.. Couldn't hurt.
Try to find something like THIS
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
cfranck1 is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 04:18 PM #6
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
I had an ac line that rubbed a hole through it. Jb weld worked great!
JayRolla is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 05:01 PM #7
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
I nicked my ac line in the exact same spot when I was cutting the frame for my front bumper.. I just painted it and it’s been fine since, I wouldn’t worry about it at all.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 05:17 PM #8
nobb nobb is offline
nobb is on a distinguished road
AC line, not critical, but it is near the bend which is a high (thermal) stress area. I don't see JB weld as being good under pressure, but what you could do is JB weld it + put a small screw type hose clamp on it which should hold. A better option than JB weld would be to braze it, but practice on some scrap aluminum first!
nobb is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 06:12 PM #9
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
I don't think it would be a good idea to braze on that while it is under pressure!
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 06:13 PM #10
If its not leaking now, it unlikely to in the future... just leave it. Worst case is you lose your AC for a while.
Old 01-16-2019, 07:30 PM #11
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
braze it
You gotta be real good to braze aluminium, real good. Being that system is pressurized even when not running it's going to blow out right about the time
it goes molten to bond.
Old 01-17-2019, 04:24 AM #12
HiLife HiLife is offline
Note to self...Keep clear of the ac line when cutting off the end cap for an armored front bumper using a cut off wheel.
Old 01-17-2019, 10:30 AM #13
Outrider Outrider is offline
Outrider will become famous soon enough
Excellent answer, for jerry-rigging it. That's what I would do, and I am a master at jerry-rigging (fixing my effups).
JB Weld alone wouldn't really do anything. If the pressure inside would rupture the metal, even a pin hole size, the JB alone would not hold it. But if held in place by the hose clamp mentioned, it just might hold. Not much to lose in trying that, except maybe $5 in supplies. JB Weld is miraculous stuff, if you keep in in compression (never, ever in tension), and roughen and thoroughly clean the metal.
If there is any liquid inside that line (even liquid refrigerant), it would be impossible to braze it. I have brazed aluminum numerous times. It really isn't difficult to do, as long as you follow the instructions and think about what is going on. And you get almost a true weld. But difficult to do that with it in place, and again, impossible to get it to temperature if there is any liquid inside it.
The best option would be to just replace that line. Of course.
I have only stayed in Holiday Inns once or twice in my life, but I am a master at fixing screwups, and I really have been a mechanical engineer for 28 years.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 11:04 AM #14
Crusifix Crusifix is offline
Crusifix will become famous soon enough Crusifix will become famous soon enough
Too far away from me, but you could use a rod of blue demon triple play to braze over it and it would be good to go, and even stronger in that area. If it concerns you, a welding shop can do it in about 5 minutes, or grab some of them yourself and do it if you have any welding or brazing experience. All you need is MAPP gas. Practice on some stuff, watch a few youtube vids on how to do it, and learn a new skill. YOU CAN DO IT!
Also, Amazon will try to sell you flux with it. You don't need flux with this rod.
https://www.amazon.com/Blue-Demon-BD.../dp/B01MCTUIUN
Blue Demon Triple Play Brazing Rod! – Works By a Hurst
Crusifix is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 01:16 PM #15
Real Name: Mark
Real Name: Mark
Originally Posted by aerobat66 View Post
If there is any liquid inside that line (even liquid refrigerant), it would be impossible to braze it...
Yep thats right. Saturated gas goes in top of condensor liquid out bottom.
There will be liquid there, thats also a high side line with the most thermal expansion and contraction.
I'd braze it on the bench since it's a one shot deal.
If AC is working now recover/filter whats in system replace line pull vacumm
check for leaks charge with a bit of PAG oil and seal conditioner leak dye.
The freon is what drives up the cost.
hard , line , nicked , radiator , replace
Help: part number for brake hard line blackfc3s 4th Gen T4Rs 3 11-12-2017 03:34 PM
Need help. Just broke a hard line on the brakes VA4Runner09 4th Gen T4Rs 8 09-29-2014 01:31 PM
Need help Finding A/C Hard line bagelsjustbagels Classic T4Rs 4 08-07-2013 07:36 PM
WTB 1990 3vze A/c Hard Line bagelsjustbagels Want to Buy/Trade 0 08-05-2013 01:21 PM
Denver area = Angle Grinder? fish0281 General Discussions 11 08-14-2012 12:44 PM
