Old 01-21-2019, 04:32 PM #31
calnhob's Avatar
calnhob calnhob is offline
calnhob is on a distinguished road
calnhob's Avatar
Okay, here are some pics of the oil change.
1st pic shows the plastic bag I used. I did spill some and that was my mistake for not using a bigger bag as I have in the past. I always have cardboard on the ground just in case. Next time I will try the tin oil in addition to the plastic bag to make a better seal.
2nd pic shows the oil filter under the wheel well with the rubber flap open
3rd pic shows the bag under the oil filter
4th & 5th pics show the ValvoMax drain valve. If I had to do it again I would buy the fumoto value, easier to use and less parts. You can see in the last pic oil dripping out so the valve might have issues.
I also use the larger Toyota oil filter (90915-YZZD3) so that makes it easier to remove since it has more surface area. Truck has mild lift and the lower plastic valance on the bumper has been removed so that also helps.
Oil change tricks to make the job easier and less messy?-img_1278-jpg  Oil change tricks to make the job easier and less messy?-img_1277-jpg  Oil change tricks to make the job easier and less messy?-img_1279-jpg  Oil change tricks to make the job easier and less messy?-img_1271-jpg  Oil change tricks to make the job easier and less messy?-img_1272-jpg
calnhob is offline   Reply With QuoteReply With Quote
Old 01-22-2019, 02:54 AM #32
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Thanks for posting the pics. What holds the bag in place under the filter? Bag stiffness?
pluton is offline   Reply With QuoteReply With Quote
change , filter , job , oil , owned
Easier oil change--New Housing Available from Jowett Performance bamma 5th gen T4Rs 24 12-06-2017 03:39 PM
Hopeful Solution to Messy Oil Filter Changes midcoma 3rd gen T4Rs 17 11-21-2015 02:39 AM
How many miles need to make my 99 4Runner 4cyl 2.7l OIL CHANGE houjames98765 3rd gen T4Rs 6 06-25-2014 11:52 AM
Want to make the change 3rd-->4th gen. Shawn5800 4th Gen T4Rs 6 02-16-2012 09:17 PM
Never had an easier oil change! Annoyed Maintenance/Detailing 17 05-14-2009 05:19 PM
