Old 04-24-2019, 03:23 PM #16
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by Earthdigger View Post
Yeah thank you for that. I just thought I need 12 bolts per cover, but it looks like there are multiply different styles I need for the 2005 V6.
Stick your VIN in here and search to your hearts content: http://japan-parts.eu/toyota/
weekendclimber is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 06:17 PM #17
pokeyman pokeyman is offline
pokeyman is on a distinguished road
I have never change the valve cover gasket just tighten the bolts everytime i change the spark plugs. 220000 mile and the valve cover is still holding up.
pokeyman is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 08:24 AM #18
Earthdigger Earthdigger is offline
Earthdigger is on a distinguished road
Mine has a leak on the passenger side, and its coming from the area where you're supposed to add sealant to it. So I might as well do them both while I'm in there.
Earthdigger is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 08:34 AM #19
Hopefully this is my last question, Ive looked at the diagram on japan-parts and I can't seem to locate the bolt that holds coils to the Valve Cover. I see the 3 that hold the valve cover to the block 91551-80660. Would anybody know what those 3 are for each coil?
Thank you.
Old 04-25-2019, 12:18 PM #20
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Thank you.
TOYOTA 4RUNNERGRN215L-GKAGKA - TOOL-ENGINE-FUEL - IGNITION COIL SPARK PLUG | Japan Parts EU
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 04-26-2019, 07:30 AM #21
Thank you so much. I should have just searched for coil pack.
Old 05-20-2019, 11:49 AM #22
blarblarjosh blarblarjosh is offline
blarblarjosh is on a distinguished road
Hate to bring up an older thread, but was anybody able to find this bolt? Doing my valve covers and need to replace one of these bolts and my local dealership is claiming that no dealership has this bolt any longer as its discontinued. I see camelback has it, but I'd rather not pay $20 for an 80 cent bolt.
Anybody happen to know what size it is so I can pick one up from a hardware store?
blarblarjosh is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 11:57 AM #23
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Just pull one bolt out, go to Lowes bolt dept, screw it into the tread gauge. That will tell you what size it is.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 01:13 PM #24
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
Josh- I have an extra OEM VC bolt that's all yours. Just cover shipping.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 03:35 PM #25
Sure I'll take it just because I like OEM. If anyone else ever needs one; I took another bolt to HD and it was an M6 flanged bolt.
Old 05-14-2020, 01:01 AM #26
Spirit's Avatar
Spirit Spirit is offline
Spirit is on a distinguished road
Spirit's Avatar
Sorry for reviving an old thread, could not find a more recent discussion on valve cover bolt size:
@blarblarjosh (or anyone), do you happen to recall the thread pitch of the M6 bolts you purchased?
---Black/Topaz 2000 LTD 4wd w/ e-locker OME 881/906s, Bilstein 5100s---
Spirit is offline   Reply With QuoteReply With Quote
Old 05-14-2020, 03:43 AM #27
Sorry it's been a long time since I did this. Wish I could help more than saying just grab one of your bolts and run over to your local hardware store and test it.
Old 02-20-2022, 11:04 PM #28
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Right now i'm replacing all fuel injectors on my 5VZ and it's funny how loose all valve cover bolts were when I checked them. I tried to hit em with my torque wrench but with the past experience of cracking my original covers and having to salvage used ones from a junkyard, I was afraid of using my torque wrench as it wasn't clicking so I just used my open end wrench and snugged them all in an X pattern (loosened all bolts first then tightened).
My theory is the grommets get soft over time and need to be tighten every once in a while.
2000 4Runner Limited 4x4 V6
Old 02-21-2022, 04:49 AM #29
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I think the grommets are meant to be soft. They compensate for expansion and contraction of the cover. While the get brittle, they shrink. As a result the bolt no longer has upward tension and is able to back out much quicker from heat cycling.
Old 02-24-2022, 12:24 PM #30
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
The key is to check and tighten them over time because the washers do harden and shrink, allowing oil to pass the gasket, which then speeds the decline of the gasket itself.
Not 100% preventable but definitely manageable and with attention, you are able to extend the life of the VCG seal and reduce the leak potential
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
bolts , cover , good , heads , valve
valve cover gasket question.. loose bolts? 95bb2 3rd gen T4Rs 24 05-01-2018 03:31 PM
Part number needed: valve cover bolts and oil cap O ring sakoluvr 3rd gen T4Rs 9 03-20-2018 02:18 PM
Torque on valve cover bolts? This may be a stupid question... OldRigNewParts Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-22-2018 06:52 PM
Engine cover bolts Stuck CAPS 4th Gen T4Rs 4 06-29-2013 02:26 AM
Valve cover bolts really do back out thatgreentruck 3rd gen T4Rs 8 04-14-2012 01:13 AM
