Old 01-17-2019, 08:59 PM #1
4runnerWiniarski23 4runnerWiniarski23 is offline
Real Name: Al
4runnerWiniarski23 is on a distinguished road
Real Name: Al
Valve Cover Bolts
Hey guys,
I cant for the life of me find the part# on where to buy replacement valve cover bolts, two of mine broke off recently when removing the cover.
***Update from my earlier thread, I got my heads completely rebuilt for a good price. Replacing as much as possible while heads are off. All belts, pulleys etc. Any suggestions or input appreciated.
Thanks in advance.
4runnerWiniarski23 is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 09:13 PM #2
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
My Toyota-fu skills says it's 90105-06127.
I also just did a poor man's rebuild on an engine (heads did not come off, however) and this was one of my orders from Rockauto, if this helps:
1998 TOYOTA 4RUNNER 3.4L V6
BECK/ARNLEY 0361583 (036-1583) Valve Cover Gasket
BECK/ARNLEY 0396428 (039-6428) PCV (Positive Crankcase Ventilation) Grommet
BECK/ARNLEY 0450297 (045-0297) PCV (Positive Crankcase Ventilation) Valve
BECK/ARNLEY 0374817 (037-4817) Intake Plenum Gasket
FEL-PRO OS30623C1 Oil Pan Gasket
GB REMANUFACTURING 8037 (8-037) Fuel Injector O-Ring
MAHLE F7460 Pipe Flange Gasket / Seal
MAHLE MS16263 Exhaust Manifold Gasket
I did more than that, but not with 100% new parts. I just did the timing belt on the old engine so I moved the entire timing belt kit to the new engine. It's way easier to do out of the engine bay, so if you want another 100k of care-free miles it's worth doing now. I should also say, unless you've got the cleanest engine in the world, if you do the water pump get some water pump gasket maker too. My surface was so pitted even after scraping it real good.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 01-18-2019, 12:58 AM #3
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Camelback says that PN is a water pump bolt but don't list a valve cover bolt in any diagram I can find on their site.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 01:18 AM #4
HiLife HiLife is offline
Toyota-fu skills are strong in that one....
I got the same 90105-06127 for the valve cover bolt and 90210-05007 for the washer seal.
And 90109-06275 for the bolt with the washer seal.
Old 01-19-2019, 02:18 PM #5
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
This is good info.
When I did my valve cover gaskets I noticed the bolts were hardly finger right. Every so often I check them, and don’t ya know it, they’re loose every time. I think the treads must be shot. Going to order new bolts and try again. Hoping that solves the issue.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 02:44 PM #6
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Take one to Hope Depot or Lowes and match it up. Why overpay for a simple bolt at the dealer? There is nothing special about them, they're just bolts.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 02:51 PM #7
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Originally Posted by Ryance39 View Post
This is good info.
Multiple issues could be occurring. Your gaskets (and bolt washer seals) have lost their pliability and or are shrinking. In your case, since you just did the VC gaskets, new bolt washer seals are definitely in order. These 2 things are what are "pushing back" on the bolts, kind of like a lock washer. With the 50 something inch pounds of torque the factory calls for, it wouldn't take much to make them loosen up again. In this case, if you have no leaks, you could use some BLUE loctite on the bolts.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 05:29 PM #8
PipoToyo PipoToyo is offline
PipoToyo is on a distinguished road
The new bolts and metal washer/grommets will resolve the loose bolts.
PipoToyo is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 06:48 PM #9
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
This may or may not help. Worth a try. Provide VIN:
PartSouq Auto Parts Around the World
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 07:06 PM #10
Real Name: Ryan
Real Name: Ryan
I did new bolt washer seals when doing the VC job.
Looking like loctite might be the fix.
2001 BMW M5
Old 01-19-2019, 07:09 PM #11
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
What's a good low-strength thread locker for the VC bolts? So damn tired of retightening every year.
Old 01-20-2019, 10:07 AM #12
Real Name: John
Real Name: John
Blue Loctite. I used it when I did my VC years ago and have never had to re tighten my bolts. Also, make sure the bolts AND the bolt holes are clean and dry. Brake Kleen and compressed air.
Old 04-24-2019, 11:20 AM #13
Earthdigger Earthdigger is offline
Earthdigger is on a distinguished road
I know this is on the 3rd gen forum, but for the life of me I can't find the bolt number for the 4th gen V6. Would you guys happen to know what that part number would be. Mine are all rusted. Thank you .
Earthdigger is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 12:30 PM #14
Real Name: John
Real Name: John
Not sure what you need or your exact year or model. Looks like you have some bolts, some studs and nuts, and some bolts (3) with seals on top. Save this site for your parts searches.
TOYOTA 4RUNNERGRN215L-GKAGKA - TOOL-ENGINE-FUEL - CYLINDER HEAD | Japan Parts EU
Old 04-24-2019, 01:40 PM #15
Yeah thank you for that. I just thought I need 12 bolts per cover, but it looks like there are multiply different styles I need for the 2005 V6.
bolts , cover , good , heads , valve
valve cover gasket question.. loose bolts? 95bb2 3rd gen T4Rs 24 05-01-2018 03:31 PM
Part number needed: valve cover bolts and oil cap O ring sakoluvr 3rd gen T4Rs 9 03-20-2018 02:18 PM
Torque on valve cover bolts? This may be a stupid question... OldRigNewParts Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-22-2018 06:52 PM
Engine cover bolts Stuck CAPS 4th Gen T4Rs 4 06-29-2013 02:26 AM
Valve cover bolts really do back out thatgreentruck 3rd gen T4Rs 8 04-14-2012 01:13 AM
