Old 01-18-2019, 11:52 AM #1
sc0rp sc0rp is offline
sc0rp is on a distinguished road
Recommended coil/shocks for carrying 400+ lbs in the back of my 3rd gen
As the title says, I routinely carry weight in the back of my 4runner for work and am looking to upgrade my springs/shocks to get a couple inches lift and better carrying ability. I was thinking LC 7 wraps but I've read some saying they sag even worse than stock. I thought about going OME and then just installing air bags but thought I'd ask the masses first. Thanks!
sc0rp is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 12:12 PM #2
RPS99SHO's Avatar
RPS99SHO RPS99SHO is offline
RPS99SHO will become famous soon enough
RPS99SHO's Avatar
I'm happy with my OME 906 coils. Very little sag when really loaded down. Plus a mild lift when empty or lightly loaded.
RPS99SHO is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 12:47 PM #3
jgue467's Avatar
jgue467 jgue467 is online now
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
Why not new Toyota OEM 99 'talls'? I think Toyota OEM are stout.
My runner has nearly 307K miles with original springs and I've loaded 800+ lbs in the rear compartment, it 'sags' only 1", that's a stout spring!
Doesn't look like a "frog" squating with all the weight, still looks/drives good down the road.
Luck and enjoy that runner.
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
jgue467 is online now   Reply With QuoteReply With Quote
Old 01-18-2019, 12:57 PM #4
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about 3bears has a spectacular aura about
I did the talls, as well as air bags
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 01-18-2019, 04:46 PM #5
thegipper's Avatar
thegipper thegipper is offline
thegipper has a spectacular aura about thegipper has a spectacular aura about
thegipper's Avatar
I have the OME 906's and they are wonderful. Excellent for towing or carrying extra weight in the back. My 2500ish lb boat/trailer barely moves the back down when I'm towing it.
In fact, the ride is even better when towing. You'll get about a 2" lift out of the deal. I think I paid $175ish for the pair.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 08:17 PM #6
Thanks! I'm looking to tow sometimes as well as I need to move large quantities of water for work. What shocks do you run if you don't mind me asking?
Old 01-18-2019, 08:30 PM #7
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
906 for me also. I carry 500+ lbs of gear all the time. 2 inch lift unloaded, loaded it goes to about 1 inch lift same as my old 99 talls when unloaded.
dogtail is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 08:58 PM #8
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice
TheDurk's Avatar
Wow, what did I do to my original talls? They sagged to the stops with a full load at only 170K. Thing looked like it was ready for take-off. 906s solved the problem.
How do you have original '99 talls on a 2001? Did you swap them in when you bought it? If you are talking about original 2001 springs, that is a whole different (and much shorter) animal. The '99 talls sag like a mfer with weight, way more than the shorter ones. Even new, they sagged with weight. I do NOT recommend. Go 906.
My Backyard Frame Swap
Old 01-18-2019, 10:12 PM #9
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC will become famous soon enough
Mark_BC's Avatar
I got some 906's but I haven't installed them yet. What shocks should I use with them?
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 10:28 PM #10
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe has a spectacular aura about Kanoe has a spectacular aura about Kanoe has a spectacular aura about
Kanoe's Avatar
I use the Billy 4600s (as do others on here), while I believe others use the 5100s (@phattyduck??) just to name 2 options.
I don't believe there is any great difference in valving, just length.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo (tbd if can be resurrected)
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 01:47 AM #11
I've thought 4600's all the way as I have a friend who did 99 talls in the rear and he had to put a small spacer lift in with 5100s to get them to operate quietly. Icon 2.0 might have to happen if I can find the right deal though. Thanks again for all the input
Old 01-19-2019, 10:56 AM #12
Insomnia Insomnia is offline
Insomnia is on a distinguished road
I remember hearing some people using the OME 861? coils and 4th gen 5100s to jack up the rear a ton and still have a decent lift in the rear after being loaded down a lot.
Insomnia is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 08:30 PM #13
lefty556 lefty556 is offline
lefty556 is on a distinguished road
What would be the best rear coil spring replacement to go with a '00 with stock height suspension? I'm not looking to lift mine. I'm competitive shooter, mostly 3 gun, and tend to haul around a bunch of gear. And I usually have one or two buddies going with me. That translates into a bunch of weight in the back end.
Thanks!
2000 Silver SR5 4X4
lefty556 is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 11:18 PM #14
The 906s don't add much height to the setup and would take care of it for you I think.
Old 01-24-2019, 10:50 PM #15
Drummermonkey Drummermonkey is offline
Drummermonkey is on a distinguished road
I'm incredibly pleased with my 906s, 5100s, and airbags.
Once broken in I found the setup a little soft without the airbags. I run the airbags at about 10psi and never see sag including when towing. The ride is phenomenal and I think it's just tall enough to be purdy.
Drummermonkey is offline   Reply With QuoteReply With Quote
back , carrying , stock , thought , worse
What rear coil is recommended for 2" lift? 6112 in the front, 5100 in back minimalist 5th gen T4Rs 29 05-24-2019 01:14 AM
FJ Coil and Shocks imola20ae 5th gen T4Rs 0 05-04-2015 03:04 PM
recommended coil packs OzzyNF 3rd gen T4Rs 12 03-13-2011 03:21 PM
Front and Back Coil Springs from 2001 4runner barjdude Classifieds - buy & sell (no commercial ads please) 0 09-27-2010 04:26 PM
