Old 01-18-2019, 01:33 PM #1
pavelvoivoda's Avatar
pavelvoivoda pavelvoivoda is offline
pavelvoivoda will become famous soon enough
MODS: Keyless tailgate power window switch...
There are a few mods I did that make a lot of difference when camping and you have to move around the 4Runner.
Like the tailgate dome lights that I installed awhile back, I also installed a secondary switch to lower the rear window without the need for a key.
The only hard part was to run 2 wires up the tailgate, thru the rubber boot, and to the left c pillar.
Then connecting is simple - using continuity on the multimeter, find the two control circuits that have a common pin when you press the switch both directions, and connect the two wires to them, and then the third wire to the common pin of the switch, which you then connect to some bolt inside the pillar. That's your ground connection to complete the circuit.
Here is the schematic of the back door ECU and which wires to splice.
Basically, using the secondary switch, you imitate the same key lock switch on the diagram.
If you sleep in the car, it is very convenient to reach and lower the window. When the seats are up, the switch is hidden by the rear seat's back and the rear window can't be accidentally lowered...say from moving luggage.
This is the end result:
MODS: Keyless tailgate power window switch...-wiring-schematic-secondary-tailgate-window-switch-jpg  MODS: Keyless tailgate power window switch...-^c4f369b446b9e1b91561b3bfc1114320e062afe98dee2bc9ad^pimgpsh_fullsize_distr-jpg
"Sadly, unlike the Bill of Rights, the UDHR has no 2nd amendment, rendering it useless. Remember that."
2person xUN diesel T4R equipped for long distance touring w/ light-duty off-roading.
1000kms range w/ subtank
pavelvoivoda is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 07:25 PM #2
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
very intuitive. Nice job
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 03:07 AM #3
RyanNapoleon RyanNapoleon is offline
RyanNapoleon is on a distinguished road
Very nice. I also used a 2nd gen switch and put it in the back rear quarter panel interior trim.
RyanNapoleon is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 04:55 PM #4
tekbench tekbench is offline
tekbench is on a distinguished road
Yeah. So my brand new 'Venture' has an up and down arrow on the tailgate, under the window. I thought that HAS to be "roll window up and down", right? No, it's lock and unlock the entire truck. Up arrow to lock, down arrow to unlock.
I'm thinking of modding that up and down arrow switch to be raise and lower the window. Not sure if that's doable or not. would only work if the truck was unlocked, obviously.
This ECU diagram gets me half way there. Thank you for this!
Kelly.
tekbench is offline   Reply With QuoteReply With Quote
rear , switch , tailgate , window , wires
Tailgate / back window doesn't work (motor works and it isn't the window lock switch) seattlee 3rd gen T4Rs 17 04-03-2022 08:58 PM
95 Tailgate Window Key Switch feusaf Classic T4Rs 7 10-16-2016 08:57 PM
Tailgate window switch not working? NW Runner Classic T4Rs 10 08-05-2014 08:33 PM
Tailgate window switch ? ncgyver Classic T4Rs 2 05-13-2013 09:14 PM
switch for tailgate window ricoman Classic T4Rs 15 08-31-2008 08:29 PM
