Old 01-18-2019, 03:16 PM #1
BucksCo's Avatar
BucksCo BucksCo is offline
BucksCo is on a distinguished road
BucksCo's Avatar
Battery Charging Issue
I replaced the alternator brush holder on my '99 the other day after a few weeks of the battery light lighting up then going away. The brushes were in bad shape, gunked up and replaced. Everything has been fine until this morning when I started up and my battery voltage was at 11.9v and the light came on again.
I turned my obdII app to monitor the volts and a funny thing happened when I stopped for a traffic light. I was waiting for the light to change and it felt like something kicked on and the battery voltage went from 11.5 up to 14.2 quickly. The 4runner kinda vibrated a little bit (I'm not sure if that's really a good description, but it reminded me of when a house heater kicks on).
Any ideas on what's going on? The battery is about 2 months old and I believe the alternator is original. It's a Denso unit.
1999 SR5 4Runner Highlander SP Imperial Jade Mica (2012-2020)
2007 Lexus GX470 Non-nav Blizzard Pearl (2023- )
BucksCo is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 03:38 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Check you wiring to the alternator but if the voltage regulator is toast, then you many want to look for a Denso remanned or one from the dealer.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 04:43 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I'd also check the ground wires. There's a few to check, engine block to firewall on the back of the passenger's side cylinder head, battery ground to fender (negative battery terminal) and if you can reach it, there's also a ground wire to the engine block on the lower engine harness that also connects to the alternator. I think the alternator uses that shared ground.
Anyway those are three to check. Look for firm connections with no movement and no corrosion or grime. If yes then remove, clean, and tighten.
326WHP 347TQ
Old 01-18-2019, 06:18 PM #4
BucksCo's Avatar
BucksCo's Avatar
Thanks. I replaced the battery ground when I replaced the battery a few months back. I wasn't aware of the other 2 grounds. I'll take a look at those.
Old 01-18-2019, 09:16 PM #5
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Also take a close look at the plug connector on the alt. Those wires are thin and break easily. You may have killed a weak one while working on it. To me, it sounds like a connection issue somewhere. I have never seen a regulator die and then come back to life periodically. They die, they die, I think.
Don't forget to check the Alt-S fuse, but I doubt that one because those don't come back to life, either, except in rare cases where they are semi-burnt. Still worth checking. Me, I'd just swap it for fun. It may be 18 years old.
In fact, best practice is to check for battery voltage on the red/blue and white wires at that alt plug (key on). Don't worry about the yellow-green as that is the dash light and that seems to be working.
My Backyard Frame Swap
Old 01-18-2019, 09:38 PM #6
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Brushes may have bedded in , what shape was commutator in?
SaulG is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 10:03 PM #7
DaMonkey's Avatar
DaMonkey DaMonkey is offline
DaMonkey will become famous soon enough DaMonkey will become famous soon enough
DaMonkey's Avatar
YouTube
DaMonkey is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 10:33 PM #8
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
That sounds like the symptoms of worn out brushes, but I know you just replaced them. I wonder if one of the new brushes is somehow hung up in it's groove and not advancing properly. Try tapping the alt. when it happens again to see if it kicks back in.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 10:58 PM #9
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
I rebuilt mine a couple times until the comutator...the spot the brushes ride on looked like the grand canyon...the first set of brushes I put in didn't work so I got another and it worked for about 3 years..maybe you got a bad set??...got 18 years out of mine though...did the gm swap since.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
alternator , battery , light , replaced , voltage
Has anyone had problems fully charging an AGM battery? Seymore Butts 4th Gen T4Rs 30 08-22-2018 11:35 PM
Have you had any problems with your 31M battery on stock charging system? e60ral 5th gen T4Rs 47 04-03-2018 05:59 PM
Need some help diagnosing battery/charging issue pudzley 4th Gen T4Rs 8 12-01-2017 01:39 PM
Battery not charging hondarcb 4th Gen T4Rs 3 03-29-2015 08:41 PM
Battery/Charging Issue Clemsonfan15 3rd gen T4Rs 8 05-15-2011 03:52 PM
