Old 09-02-2021, 09:55 AM #31
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by eckertmg View Post
To close the loop here, they ended up finding the issue. It sounded like the original culprit was the upper control arm / ball joint, which they started to replace under warranty. Then when they started the repairs, for some reason they tacked on the lower control arm / ball joint, and a number of other "bolts and bushings that were rusted out". It sounded like the lower control arm was just easier to replace with the upper, and I guess it was approved under warranty. Didnt push to hard on that, but if I was paying, I would have had a more detailed conversation there. 1400$ all in
Hope this helps someone!
I'm glad they figured it out, but you're in the wrong section. The newest vehicle in this section is from 2002. There's been some changes since then. You have a 5th gen and this is the 3rd gen section.
coming , greasing , noise , turning , wheel
Noise from drivers side dash...Just me? Socco 5th gen T4Rs 28 12-28-2019 08:49 AM
Front Drivers Side noise natetech 5th gen T4Rs 7 12-19-2018 11:39 AM
ICON Drivers side UCA making noise Elpaca19 5th gen T4Rs 16 06-30-2017 10:41 PM
Creaking noise on driver side rear JeratBP 4th Gen T4Rs 3 04-01-2017 08:54 AM
Drivers Side Front Popcorn noise FrontRange4Runner 5th gen T4Rs 9 02-06-2014 11:36 AM
