Originally Posted by eckertmg
To close the loop here, they ended up finding the issue. It sounded like the original culprit was the upper control arm / ball joint, which they started to replace under warranty. Then when they started the repairs, for some reason they tacked on the lower control arm / ball joint, and a number of other "bolts and bushings that were rusted out". It sounded like the lower control arm was just easier to replace with the upper, and I guess it was approved under warranty. Didnt push to hard on that, but if I was paying, I would have had a more detailed conversation there. 1400$ all in
Hope this helps someone!
I'm glad they figured it out, but you're in the wrong section. The newest vehicle in this section is from 2002. There's been some changes since then. You have a 5th gen and this is the 3rd gen section.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
