Old 01-20-2019, 01:04 AM #1
Hidjet Hidjet is offline
Hidjet is on a distinguished road
Problem: Minimal droop on front suspension for new bumstop install
Hey all, I posted in the plasticguys bumstops thread but thought I could get a few more responses here without clogging up that thread.
I bought the Durobumps front and rear 3.5 set of bumps. The 3.5 rear set was a breeze. No problems with the install.
Then I moved to the front set. After having jacked up the 4runner, I placed the jack stands on the frame in order to get the fronts suspension droop necessary for the install. That was not the case. After removing the bumpstops on the rear of the front LCA I noticed there was only about two inches of space above the new Durobumps after they were placed on the LCA. That left me just barely enough space to squeeze in a short socket and ratchet in between the Durobumps and their respective contact points.
Long story short, I didn't get much droop on the front suspension and the install was a lot more tedious than what should have been. I watched Timmy's video and he had a ton of space in there to do the install compared to what I was working with. The install is done now but something was not right. Any input would be great if you guys have some ideas as to what I missed. Thanks.
Hidjet is offline   Reply With QuoteReply With Quote
Old 01-21-2019, 02:01 PM #2
I already answered in the other thread, but here it is again...
The OEM shocks are shorter than basically all of the aftermarket shocks that are installed by now (Including "OEM style" ones like Bilstein 4600's).
See the 4th page of this link:
http://www.sonoransteel.com/download...aRearShock.pdf
You can easily get extra room by removing the swaybar endlink and the shock bottom bolt. You may need to also pry the assembly down with a pry bar to get all the room you need (the bushings might hold the knuckle up).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-21-2019, 03:55 PM #3
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
Can you show us some pics?
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 01-21-2019, 05:51 PM #4
Sorry, no pics. I finished the install without taking any. If anyone has watched Timmy's video on this install, just imagine having only about half the space he did to do the install.
I did have the endlinks disconnected to swap out all the bushings, and that didn't net me anymore space..
durobumps , front , install , rear , set
What limits rear suspension droop? Kirk_B 3rd gen T4Rs 11 07-19-2018 01:12 PM
Suspension Kit for minimal lift? WI_4Runner 4th Gen T4Rs 17 06-08-2017 12:27 PM
Upgrade Suspension / Minimal Lift Jabberjaw 5th gen T4Rs 39 02-15-2015 11:56 PM
Minimal sweat CB install (pics) bwake21 4th Gen T4Rs 8 01-30-2013 01:02 AM
ome suspension install, think i have a problem?? the_josh Off-Roading 11 10-19-2011 10:09 PM
