Old 01-20-2019, 01:17 AM #1
zzzzzzz7zzzzzzz zzzzzzz7zzzzzzz is offline
zzzzzzz7zzzzzzz is on a distinguished road
Weird metal tapping/clicking noise from engine
Hey guys,
Curious if you have any insight as to what might cause this noise? 98 auto Limited 3.4 engine. It's very very intermittent. I have only noticed it about 3 or so times over the past 1.5 years. Two times came after a water/mud crossing and the other when power washing the engine bay.
The ticking/tapping noise will happen in park, drive, reverse, or idle. It's pretty loud and is easily heard from the inside. It will get louder with an increase in RPMs in neutral, but goes away at about 3k RPM. Sounds like its coming from the belt or fan, but not sure. It only lasts about anywhere from 5-20 minutes and then goes back to normal.
Heres a short Youtube link of the sound from inside the T4R and outside.
YouTube
Thanks
zzzzzzz7zzzzzzz is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 02:45 AM #2
spartacus's Avatar
spartacus's Avatar
Originally Posted by zzzzzzz7zzzzzzz View Post
Hey guys,
YouTube
Thanks
first guess sounds like the water pump bearing is shot. Have the timing belt, pulleys and water pump replaced with in the Last 90k miles?
Old 01-20-2019, 01:00 PM #3
Thanks, I'm not sure on the last time for any of those parts. It's at about 156k miles. Drive belts are starting to show wear as well. I've been pushing it off, but it's probably time to get in there and change them out with the pump.
Old 01-20-2019, 03:52 PM #4
spartacus's Avatar
spartacus's Avatar
Make sure to get oem or asin parts. There are several writeups and vidros on this forum for doing the job yourself and also recommendation for parts or timing belt kit.
engine , inside , noise , rpm , times
rear metal clicking noise KBToys 4th Gen T4Rs 3 12-13-2022 04:38 PM
Loud clicking (metal-on-metal) noise - 5th Gen mgosts 5th gen T4Rs 10 04-13-2017 01:54 AM
Reverse to Drive weird clicking noise webbbj 4th Gen T4Rs 6 04-11-2015 08:29 PM
Clicking/Ticking noise from the engine GuardianBU 4th Gen T4Rs 6 02-21-2007 11:51 PM
Tapping noise in engine rosmith2 4th Gen T4Rs 4 04-05-2004 09:33 PM
