01-21-2019, 05:36 PM
Help! Coolant all gone in Radiator!
Sup guys,
I drove my 2000 T4R Limited (211k miles on the clock) to Detroit, MI. this past weekend to attend the Auto Show....5hrs to Michigan and 5hrs back to Chicago. She was a beast in the snow and freezing weather all the way there and back. Anyhow, car drove fine to and from Michigan without a hiccup. No overheating, no nothing. Got back home to Chicago Saturday night and all was fine. Sunday morning, I started the car and it started up just fine....drove it about a mile, then all of sudden the car started sputtering. Felt like a cylinder was dead or something. Idle looked fine on the tachometer, and still drove but sounded like a bad misfire. Got to my folks place, and opened the hood....and looked around, all looked fine. I squeezed the upper coolant hose, and there was no coolant in it. I popped the radiator cap off, and the radiator was bone dry. The coolant reservoir still had coolant in it....but no coolant in the radiator. The temp was not overheating though. I didn't see any white smoke, so I assume no blown head gasket. I didn't thoroughly look under the car for leaks, but from up top, I could not see any coolant leaks.
Anyone have any idea what could be happening? I love my truck very much and would hate to have it end this way. Any advice would be greatly appreciated.
Thanks.
Fadiddy's Build Thread | 2000 Limited 4x4 | e-Locker | ARB Bumper | IPF Lights | Tundra TRD Front Coils & OME 890 Rear Coils | Bilstien 5100 Shocks | Tundra Brake Upgrade | Spidertrax 1.25" Spacers | 285/75R 16 General Grabbers AT2's | Toyotec Bump Stops and Diff Drop | E7006 NAV
01-21-2019, 06:02 PM
Real Name: Keith
Real Name: Keith
You may still have antifreeze in it, just not showing up top. Top it off and see how much it takes to fill it and if its leaking anywhere.
01-21-2019, 06:11 PM
Also check the transmission dipstick.
18 Audi A6 3.0T - APR Tuned, RS6 Interior 19 Audi A6 3.0T
01-21-2019, 06:40 PM
But would the coolant be that far gone? Usually there is still some coolant at the top of the engine no?...I mean in the upper hose?
I did replace the radiator two years ago when it took a dump on me (strawberry milkshake survivor). You think there is something with the trans? If so, what could be trans related?
01-21-2019, 06:54 PM
Real Name: Rich
Real Name: Rich
The coolant isn't always at the top where the cap is, since you have coolant in the rez I don't think you ran it empty,you can have a tight rad cap that won't top off the rad when you shut it off, since you replaced the rad a few years ago did you use a toyota cap?..I've had bad luck with the cap the rad comes with{aftermarket}...since it's so cold out I'm sure you were running the heat and you would've been really cold if you were out of coolant. plus the temp gauge doesn't work if there is no coolant. How much did you dump in to top it off?? If it's less than a half gallon I'd go after the rad cap...
Checking the trans fluid will tell you if the trans cooler popped again.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
01-21-2019, 07:30 PM
Real Name: Gary Blake
Originally Posted by Fadiddy
Sup guys,
Thanks.
What was the condition of your antifreeze (after the rad switch, did they put new fresh stuff in and if so did they mix it for max cold temperatures)
If your Sunday morning was as cold as ours here in southern Ontario (-25C) and your antifreeze wasn’t up to snuff you may just have popped a frost plug or hose connection.
I would refill and run it and check for leaks. If the antifreeze disappears again and there is no visible leak you know you have a different problem.
Don’t like the sounds of the engine miss though, likely the cold weather could have saved you from an overheat problem if you shut it down soon enough.
Disappearing antifreeze + no leaks + engine miss, you may be looking at a head gasket situation.
Good luck with it and remember, these old girls never really end, just depends how bad your 3rd gen addiction is, most things can be fixed.
Gary (Non techie driveway wrencher)
2000 SR5 4 Runner, 3.4, 5spd, 4WD
Shrockworks front & rear bumpers & sliders, Warn VR10,000S, Optima Yellow Top, Icon Uniball UCA
Toytec Ultimate Lift Kit (Soon to be replaced by Icon)
Method 305 NV Racing Wheels
01-21-2019, 09:27 PM
If the rad is low there might not be be any fluid in the top hose.
I wouldn't be concerned about that.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
01-22-2019, 04:02 AM
Coolant low and misfire.....not the greatest thing to hear.
FYI i had disappearing coolant and strange misfires for quite some time due to a headgasket but did not show white smoke until a little later.
What do the plugs look like?
1999 Limited
265/75/16 AT51's
Bilstein 4600
01-22-2019, 08:23 AM
All of that coolant went somewhere. Fill it back up and monitor it closely for leaks. I've had two different heater hoses leak, both were up against the firewall so they are hard to notice. They also both leaked directly onto the crossover pipe on the exhaust so I would never have any coolant on the ground (it would just burn off). You'll want to look closely in that area.
The fact that you had misfires concerns me. Hopefully you just have a leak somewhere and not a HG problem.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
01-22-2019, 12:03 PM
If you take the skid plate off and put a piece of cardboard under the engine it might help to figure out approximately where it's leaking.
01-22-2019, 02:19 PM
If you lost enough coolant that the temp sensor wasnt in coolant anymore, it was then reading air temp and you were probably over heating but you didnt know it.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
01-22-2019, 06:20 PM
Might still be some water in there. If it was winter I'm sure he had the heat on. If it's low you'll hear the water slosh around behind the dash. I had a slow leak cause the same crap. Radiator was bone dry when I pulled the cap but it really took a while before the gauge would budge.
01-22-2019, 06:23 PM
Real Name: Jerod
Real Name: Jerod
I've not seen a 3rd gen get the air bubble issue but the 2nd Gens would do that from time to time. It actually caused the opposite, the engine would super-heat the air bubble, causing steam to rise to the sensor and your temp gauge would spike into the red rather quickly, then the bubble would pass and then it'd go back down. Scary as heck, especially since those engines blew head gaskets if you looked at them funny.
01-23-2019, 04:16 PM
Thanks everyone for the input. I am going to pull the motor soon, and do a full rebuild. It will be just in time for tax season, so I might just bite the bullet and get a Magnuson supercharger kit. I love this truck, and the money I have put into it with the lift, tires, suspension, brakes, etc... I don't think I can part with it.
Now, I just have to figure out where to start on removing the current motor....geez.
01-23-2019, 04:32 PM
Did you verify it's head gasket? You'll feel really foolish if all it needs is plugs and a coolant top-up.
