Old 01-21-2019, 06:34 PM #1
ben9105 ben9105 is offline
ben9105 is on a distinguished road
P1127
I went and got a new battery yesterday, they gave me the wrong one and I didn't notice the terminals were reversed until it was too late. The truck wouldn't start and no electrical. I got it home and replaced the alternator fuse and the truck would not start but I was getting it to try to turn over.
I finally got the truck started and running but now the VSC OFF and VSC Trac are both lit up along with the CEL. The throttle is giving almost no response as well. I have to almost floor it before I get any response and it won't really go anywhere. I do have a P1127 code which looks like it's "ETCS Actuator Power Source Circuit Malfunction" but the ETCS fuse is good and only the towing fuse was blown other than the alt fuse.
I don't see anything obviously wrong with the harness but it could be somewhere I can't see.
The vehicle is a 2002 Sport, stock.
Any ideas? Could it be the ECM?
Thanks
ben9105 is offline   Reply With QuoteReply With Quote
Old 01-21-2019, 07:03 PM #2
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
Battery reverse is always an interesting time, I'd look for other fuses blown, I would remove the fuses and look at it to make sure it didn't get hot, they'll be a dark spot center, anything that was turned on when you hooked up the battery and hit the key can be damaged,,,once I go through all the fuses I a cap drop on the system to reset it to 0....{hook the positive and negative battery cables together} half hour is usually enough time,,when you start it after hooking the battery back up make sure the ac and all loads are off,,,start it and don't touch anything for about ten minutes...then slowly add loads like heat or ac,,I go through each gear while parked nice n slow to get the trans in sync too...if you still have stuff not right you'll need more help...but give this a try.
what year is this runner??
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
Old 01-21-2019, 07:09 PM #3
Thanks for the reply. I thought I had that in there but it's a 2002 sport. Would the battery need that if it's brand new? I'll give it a shot either way though.
Thanks
Old 01-21-2019, 09:39 PM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by ben9105 View Post
...I do have a P1127 code which looks like it's "ETCS Actuator Power Source Circuit Malfunction"
Thanks
Per our beloved FSM a P1127=Open in ETCS power source circuit or ECM.
One or both are most likely fried and/or shorted. Check out page 294 of FSM for details of how to test each.
Old 01-21-2019, 09:49 PM #5
WWRD99's Avatar
Real Name: Rich
WWRD99's Avatar
Real Name: Rich
That cap discharge isn't for the battery its to clear all memory out of the pcm for learned adapt,,,I'm hoping you didn't blow the pcm,,,most of the time you blow the inputs not outputs.
Old 09-17-2019, 11:37 PM #6
Jreg0028 Jreg0028 is offline
Jreg0028 is on a distinguished road
Any luck or info? I'm having the same exact problem.
Jreg0028 is offline   Reply With QuoteReply With Quote
etcs , fuse , response , truck , vsc
