01-22-2019, 02:17 PM
Changed oil 5.5 quarts shows low
Never had a issue. Changed my oil. Filled it with 5.5. It’s showing below first dot. Wtf. No leaks, everything is bone dry. How is this happening ? Parked on flat driveway.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
01-22-2019, 02:27 PM
You got short quarted! Take that stuff back and tell them the bottles were not full!
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
01-22-2019, 02:32 PM
Yup - noticed that a long, long time ago.
Mine takes closer to 6 1/8 to show full on level ground.
Someone did not measure correctly.
01-22-2019, 02:47 PM
Guess I’ll let it sit so it drains to the bottom. Measure and fill till it reads normal. I guess 5.5 quarts isn’t the correct amount lol?
Could I have really gotten not full bottles? 3 cans were from Walmart and 2 were from autozone.
01-22-2019, 02:52 PM
Real Name: Ash
Real Name: Ash
6qt
Always 6qt in mine to full, using the standard capacity filter.
1998 SR5 - 3.4/Auto/151k. Toytec, OME, Savage Off-road, Addicted Off-road, 4Crawler, Spidertrax, TBU, ePCK, B&M, ViAir, '00 grill/headlights, Firestone MT, CB mod, RB mod.
01-22-2019, 02:55 PM
Same here... Has always taken 6 quarts.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
01-22-2019, 02:59 PM
Real Name: Mark
Real Name: Mark
Yep you got short quarted, Both with YZZD1/standard filter 6 qt dead on full.
01-22-2019, 03:02 PM
Maybe it was the Jersey Devil. Anywhere from 5.75 to 6.2 quarts needed depending how long I let the old stuff drain out.
01-22-2019, 03:32 PM
Missing oil
Happened to me as well. I purchased a 6 qt box of 5-30W at Walmart (Oil came in box and was in a large plastic bag). I used 5.5 in my guestimation as the container did not have any markings on it. I had to use the remainder of oil to bring it up to specs. Never happened before.
01-22-2019, 03:48 PM
I swear the amount of oil mine takes changes every time. It's usually between 5.5 and a little over 6 quarts. Plan ahead and make sure you buy enough.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
01-22-2019, 03:50 PM
6 Quarts of oil every time gents. If you drain properly and replace filter - must put in 6 quarts.
'99 Millenium Silver SR5 | 5.29 Nitrogears/ARB lockers | 35s | Supercharged
Build Thread
01-22-2019, 03:52 PM
That's been my experience, especially using the longer filter. That is, checking level after a quick run to check for leaks.
Sometimes it ends *slightly* overfilled, but that also hasn't been a problem.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-22-2019, 04:36 PM
Yeah I always put 6 also. Idk why I put 5.5 this time. But it wasn’t enough. I don’t think it’s low enough to **** any up. Put a quart and a half almost. To bring it to the second dot.
01-22-2019, 06:10 PM
Real Name: Jerod
Real Name: Jerod
This thread is great, I thought I was crazy with my engine swap and changing the oil. My old USDM engine took 5.5 quarts with a filter change right to the top of the full level. First oil change with my JDM engine, 5.5 doesn't even register on the level between the dots. 6.0 quarts brings it acceptable. So weird.
01-22-2019, 06:23 PM
This is what happened to me last weekend when I changed my oil... OEM filter and 6 quarts to full. Checked the next morning and was right at the full dot.
