Old 01-26-2019, 02:44 PM #1
4runnerWiniarski23 4runnerWiniarski23 is offline
Real Name: Al
4runnerWiniarski23 is on a distinguished road
Real Name: Al
Help Needed final reassmble
Hi guys,
I got my freshly rebuilt heads and everything back together. I am on the final bits of putting things back together but have a few questions.
I am not sure where this connector goes (behind the power steering pump) hoping i didnt miss something...see pic below, I also cant figure out what vacuum hose connects to the (red pointed pic).
Taking a break for some lunch and must needed warm up. Thanks in advance.
Help Needed final reassmble-img_3696-jpg  Help Needed final reassmble-img_3697-jpg
4runnerWiniarski23 is offline   Reply With QuoteReply With Quote
Old 01-26-2019, 03:09 PM #2
Lamer's Avatar
Lamer Lamer is offline
Real Name: Jake
Lamer will become famous soon enough Lamer will become famous soon enough
Lamer's Avatar
Real Name: Jake
not sure about the vacuum line, your throttle body is different than mine.
but that wire, I might be able to help. went out and took this picture for you. I am not sure if this is it, but the only wire I have in that area with a plug like that is show here. connects fwd of the header, and lower than the header.
hope this helps.
https://i.imgur.com/WQdryKXm.jpg
The Sequel - 1996 4Runner SR5 - Houston, TX
The Original - 2001 4runner SR5 - SOLD
Etsy Page - Custom Pinstriping and Sign Making
@8LinePinstripe: Instagram
Lamer is offline   Reply With QuoteReply With Quote
Old 01-26-2019, 03:21 PM #3
Real Name: Al
Real Name: Al
hope this helps.
That wire looks like the ac compressor wire which i do have plugged in, thanks for trying i appreciate you grabbing a quick.
Old 01-26-2019, 03:35 PM #4
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
might give you idea.
Help Needed final reassmble-img_0234-jpg
Old 01-26-2019, 03:57 PM #5
Real Name: Al
Real Name: Al
Definitely helps thank you
Old 01-26-2019, 04:15 PM #6
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Single wire connector is likely a sensor. Oil pressure or a water temp sensor? Something in the block/head in that location?
Sorry, I am not familiar with the v6 layout.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 12:31 PM #7
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
That sensor connector looks like the Power Steering Pressure switch which I believe is threaded into the pipe fitting that bolts to the pump.
See if it matches this connector above.
My Backyard Frame Swap
Old 01-27-2019, 02:35 PM #8
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
IS the connector on the timing cover plugged in?
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
back , final , needed , pic , vacuum
Final Drive crosswhite 4th Gen T4Rs 3 07-22-2013 01:05 PM
Help Needed - Final Stages of Wiring Aux Lights to OEM switch tj043 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-08-2012 06:26 PM
Ok, One Final Goodbye Dark Runner 3rd gen T4Rs 6 12-07-2010 07:08 PM
Final Decision needed - lifting kormaster 4th Gen T4Rs 15 07-12-2010 03:41 PM
