Old 04-19-2019, 04:03 PM #16
arbys arbys is offline
arbys is on a distinguished road
Originally Posted by 19963.4lsr5 View Post
I wish I could say the same.
Were your's supposedly "direct replacements"?
arbys is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 08:46 PM #17
19963.4lsr5 19963.4lsr5 is online now
19963.4lsr5 will become famous soon enough
I went back to the old nuts. My 96 they all broke the studs or ripped the threads off. My 97 they came off like a normal nut so I reused them.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 04-19-2019, 09:21 PM #18
How many miles did the original CC last?
Old 04-20-2019, 12:28 AM #19
If your referring to the CAT. My CAT was factory on the 96 and the 97. Both Federal. I have the 96 as a spare.
The 96 got totaled and removing the engine and trans I broke or stripped every stud on the exhaust. I put the engine in the 97 I bought with a dead engine and on the 97 all the exhaust nuts came off normally.
Old 04-20-2019, 12:30 AM #20
About 250k miles on the 96 and the 97 is going strong at 270k miles
Old 04-20-2019, 01:24 AM #21
nissanh nissanh is offline
nissanh will become famous soon enough
I installed a CAT from Eastern Catalyitics on my LC and the check engine code came to P0430 went away on its own. The built quality is identical to the OEM cat came off the truck. The flanges and tubing are thick as the OEM and came with the necessary gaskets too. They offer 50K or 5 year warranty on the CAT.
Install new OEM flange bolts and nuts.
Part Number: 9008010064
BOLT, FLANGE
Part Number: 9008017187
NUT
Old 04-20-2019, 08:58 AM #22
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail will become famous soon enough dogtail will become famous soon enough
MY GARAGE
dogtail's Avatar
Real Name: Keith
MY GARAGE
Different types of bolts/nuts have their own torque rating. I just tightened up the brass nuts by feel with backed off a bit from where I would go on a steel nut. I just checked to see if there is a torque rating on the package, there isn't. I wouldn't worry about a torque rating for a cat, other than getting it snug.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*1998 3.4L, 2wd/auto, rust free from south, slated for 4wd/5spd swap from my 2000 parts rig
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 02:11 PM #23
I was worried about not crushing the exhaust donuts enough.
Old 04-22-2019, 02:27 PM #24
VernySanders VernySanders is offline
VernySanders is on a distinguished road
My magnaflow just came in the mail today!
VernySanders is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 10:47 PM #25
sugjavier sugjavier is offline
sugjavier is on a distinguished road
Is there any aftermarket CATs that last more than 2-3 years?
I want something Stainless Steel since I'm running GIBSON Catback Exhaust System
I mean at this point, I feel like OEM Cats will be more worth it since they last so long...
Also, do people replace just the rear cats or the front ones too?
I have a 2001 which I believe has 2 cats.
2001 Toyota 4Runner Limited. 215,000 miles.
sugjavier is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 12:13 PM #26
96RedRunner will become famous soon enough 96RedRunner will become famous soon enough
Originally Posted by sugjavier View Post
Also, do people replace just the rear cats or the front ones too? I have a 2001 which I believe has 2 cats.
Most people change both my 01 has two, Best to change both sensors also.
advice , cats , home , replaced , welded
Aftermarket Catalytic Converter...or Toyota derek l 3rd gen T4Rs 21 11-26-2018 01:27 PM
cat converter advice Dale Bob 3rd gen T4Rs 5 04-10-2018 12:56 PM
OEM or aftermarket catalytic converter Runner4u Problems & Warranty Issues 0 03-02-2011 03:05 PM
Advice needed: OEM HU, Ipod, aftermarket Amp/Sub in '96 4runner? eimkeith Engines / Suspension / Wheels / Tires / Audio / Accessories 1 08-17-2008 01:40 PM
Need help installing line converter for aftermarket amplifier gkatmar Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-22-2008 03:38 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
