Old 02-10-2019, 09:48 PM #31
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
All good. Ordered uppers and lower.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 01:50 AM #32
Jaysen4runner's Avatar
Jaysen4runner Jaysen4runner is offline
Jaysen4runner will become famous soon enough
Originally Posted by eimkeith View Post
Lotus is definitely an easier install, but since I know that a lot of you guys wheel hard, something beefier was in order...
Does the lower bracket interfere with lil gas skip?
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
Jaysen4runner is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 08:25 AM #33
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
I don't know, but I don't see how it could... (I've never run an aftermarket tanks skid, and I'd already relocated my tank when I made these.) - perhaps @Plastics guy or @theesotericone could get a photo of the clearance between tank and LLS when convenient?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 02-13-2019, 12:06 AM #34
Here is the location I was talking about?
Upper & Lower Link Mount Reinforcement!  (ULR & LLS)-20190212_200400-jpg
IG: Jaysen4runner
Old 02-13-2019, 12:13 AM #35
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
That location gets covered with the LLS.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 02-13-2019, 12:20 AM #36
Doesn't contact the gas skip mount?
IG: Jaysen4runner
Old 02-13-2019, 04:51 PM #37
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
oh yeah - you'd definitely have to cut back the mounting flange on that tank skid - looks like it might clear the bolt, though.
keith
eimkeith.com
Old 02-13-2019, 11:20 PM #38
Thank you Eimkeith. Just to clarify, I know my slider mount in the way!😅
IG: Jaysen4runner
Old 02-28-2019, 10:10 AM #39
Here is mine, did the driver side. The harder side first. Have to drop the gas tank. But its easy if the bolts are not rusted. And if you have a lift+transmission jack. I got mine powder coated first. It was cheap, lets me know that the backside that is against the factory metal will be 100% painted after welding.
I trimmed a little bit of it to make it fit better, also where my rock slider is mounted i had to trim that little area. Maybe include longer bolts with the purchase of these items for future?
Old 03-17-2019, 08:49 AM #40
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
shipped out the first of the ULR orders yesterday - will work on some installation photos today for you guys.
keith
eimkeith.com
Old 03-17-2019, 06:13 PM #41
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
Ok, so this one isn't as simple to install as the LLS (but it's pretty straightforward, nonetheless.) It's a tight fit, that requires some tapping and clamping into position.
First, here's the problem with using upgraded joints in the stock upper link mount:
you can see that there is no room for it to articulate without binding the mount - which leads to a twisting/tearing failure.
You can see in the same photo where the reinforcement creates extra room for the joint to pivot without interference.
So, to install; first, tap the ULR into place and insert the factory bolt (it will be tight - make it go where it needs to to get the bolt installed.)
then, take a sharpie or paint pen, or something similar, and mark where the welds will be on the stock link mount, then remove the ULR.
then, remove the paint from those areas with whatever tool you're comfortable with, to prepare for welding.
now cut out this portion so that the big joints have room to move freely:
reinstall the ULR (I advise spraying the inside of the ULR with weld-through primer first, so that is has some corrosion protection), and clamp it front-to-back so that the rear face is tight against the stock mount.
- you'll know that it's tight when the "e" logo is centered in the factory hole:
(not tight)
(good to go)
tack the back at the base, then clamp the sides so that the flanges are tight to the original mount:
great; now weld it.
finish it up by positioning and welding in the supplied corner reinforcement (the little triangle) and paint it, and you're good to go!
keith
eimkeith.com
Old 03-27-2019, 09:05 AM #42
Taylor20's Avatar
Taylor20 Taylor20 is offline
Taylor20 will become famous soon enough Taylor20 will become famous soon enough
Taylor20's Avatar
Tracking within 10 minutes of ordering??.....
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
Taylor20 is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 01:18 PM #43
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
sometimes things just work out well.
(and thanks for the order!)
keith
eimkeith.com
Old 07-08-2019, 10:06 PM #44
Taylor20's Avatar
Taylor20's Avatar
Do you have a picture of where the triangle reinforcement should go? Finally going to have time to install these.
02 Sport
4xI - AED - Savage
Old 07-08-2019, 10:22 PM #45
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
Here you go:
keith
eimkeith.com
links , lls , lower , mount , stock
TC Lower Link Skids STX4Runner 5th gen T4Rs 22 03-20-2021 11:15 PM
Lower Link Mount Reinforcement rkntoy 3rd gen T4Rs 9 12-06-2018 07:40 PM
FS: 5th Gen RCI Differential Skid & RCI Lower Link Skids (Denver, CO) tutawted For Sale: T4R Items 3 03-30-2017 12:45 AM
Frame failure at rear lower control link mount Steve240 3rd gen T4Rs 1 05-20-2015 05:11 PM
