Old 03-04-2021, 05:47 PM #1
rayray61 rayray61 is offline
rayray61 is on a distinguished road
No heat
Hello all so I have a 98 4Runner SR5 and I have no heat I have changed the radiator the heater core I flush the system I have done everything that I know how to do and theres no heat or very very little depending in the temp. Any ideas?
rayray61 is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 06:30 PM #2
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Do you have a rear heater?
Its very possible you have air in the system. Park the car on a slight incline and take off the radiator cap and turn it on. Let it warm up for a minute and hold the RPM(In park) at 1500-2000~ RPM for about 2 mins. If there's air in the system then it should come out. It will also obviously spill coolant out of the radiator top so be prepared for that.
I did this the other day and my heat went from sorta lukewarm to as good as new.
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 06:44 PM #3
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Sorry to be Cap'n Obvious here with a Copy-n-paste - is your valve opening?
HVAC Heater Control Valve
Part Number: 8724035070
Supersession(s): 87240-35070
Fits 4Runner (1998 - 2002)
Heater Control Valve - Repair or Replace
A heater control valve diverts hot water (coolant, or antifreeze) from the radiator into the heater core in your vehicle’s cabin, resulting in soothing warm air. If your heat has stopped working, your Toyota 4Runner may require a replacement heater control valve.
Old 03-04-2021, 10:16 PM #4
ej86923 ej86923 is offline
ej86923 is on a distinguished road
Spill free coolant funnel is the answer to the spilling coolant. It also brings the level higher than the heater core which is usually the highest part of the cooling system.
ej86923 is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 02:35 AM #5
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
I had a clogged heater core, and I ran a coolant flush through the system when I changed the coolant and that made a huge difference.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 07:38 AM #6
If you have a properly operating rad cap and a cooling system that is sealed (including the hose to the expansion tank, and you keep your tank level at the upper full mark) any air in the system should be purged in around 3 heat cycles.
Unless you have the stainless piping going to your aux heater those pipes rust out and leak.
As you drive all the air should collect at the top of the rad. Shutting off the engine and air in the block should rise to the upper rad hose.
Old 03-05-2021, 01:14 PM #7
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
agree with this. I was recently having issues, and it was the cap and the hose going into the expansion tank.
Its not hard to check if the heater valve is working, turn on and off and see if the lever is moving, and if it is, make sure its not spinnig on the shaft, just be warned, at this age, the heater control valve can be brittle, have read mixed reviews on after market ones.
depending , flush , heat , system , temp
*Heat On*: Heat blows on passenger side, cold air blows on driver's side biv117 4th Gen T4Rs 4 12-21-2023 07:09 PM
Another No Heat/Warm heat thread.. please help troubleshoot bentos1 3rd gen T4Rs 39 12-08-2022 12:23 PM
No heat diagnosis and solution, heat blend door servo actuator 4by4runr 4th Gen T4Rs 4 09-15-2019 09:10 PM
Cold heat coming out but auxiliary heat? Gremcat Classic T4Rs 4 11-19-2014 09:57 AM
Heat\AC Rescue84 3rd gen T4Rs 1 09-02-2006 02:09 PM
