01-28-2019, 04:29 PM
#16
Real Name: Jeremy
Real Name: Jeremy
Used to run optimas and switched over to the X2, I actually run this same battery in my offroad rig..hands down the best battery I've ever bought. dual purpose, starting and deep cycle.
SLI24FAGMDP - X2Power Premium AGM Battery for 2018 Toyota 4Runner V6 4.0L 585CCA Car and Truck at Batteries Plus Bulbs
not inexpensive but well worth the $$ in my book.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
01-28-2019, 09:09 PM
#17
Official Vendor
Official Vendor
I use Interstate also. No complaints here.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
01-28-2019, 09:36 PM
#18
Real Name: Bill
Real Name: Bill
I got 8 1/2 years out of an interstate battery in my '95 Celica gt. Can't complain. Also, last year I replaced and OEM battery in my '97 4runner that was almost 5 years old with a new OEM Toyota battery. I prefer the non maintenance free batteries as long as you check them and add distilled water once in awhile.
'97 T4R LTD 4WD desert dune, bone stock, factory E-locker, RS3000, Scangauge II, Hella 450's, 191k
01-28-2019, 11:10 PM
#19
Real Name: Rich
Real Name: Rich
Originally Posted by sawguy
I'm still on my original Toyota battery in my '08 Tundra...do the math.
That's crazy!! I wonder if it's that TV brand that used to make them and get shipped over when new...The replacement ones from Toyota I think are made by Interstate, I just like the Toyota sticker and the long warranty...My last one I took out of my 99 went in my 97 so it's still going...wanted a new one with the big alternator swap I did.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
01-29-2019, 03:02 AM
#20
Real Name: Keith
Real Name: Keith
Originally Posted by JAXJeremy
This appears to be a rebadged Northstar NSB-AGM24F.
01-29-2019, 08:55 AM
#21
I've had no issues with two interstate batteries.
I always bought Die Hard batteries when I had my jeeps. I am pretty sure I had over a 100 winch extractions on one Die Hard (and Milemarker) and it still worked till I sold the jeep. We went wheeling every weekend with a sole objective of getting stuck and we did too often. There was a day I had to pull cable 22 times.
1999 Limited
265/75/16 AT51's
Bilstein 4600
01-29-2019, 01:44 PM
#22
I replaced the battery in my 2000 SR5 just this last fall. The previous one was a NAPA battery that was in my 1998 Tacoma when I bought it in 2008. The previous owner had to replace it in order to complete the sale, so it was brand new then. That's 11 years on a basic middle of the road battery. When I am out west for a month long summer tour in my VW Westy the 4Runner sits in the driveway without being started for the month. The last two years the battery was dead upon my return and needed a good slow charge.
Yeah, I know. You'd think I'd learn after the first time and disconnect the negative cable before leaving.
Anyway, I bought an AGM battery at my local farm/home store (Farm & Fleet) for $130 on sale. It's a 34R with 775 cca, 890 cranking amps and reserve capacity of 120A/hr. The battery is manufactured by East Penn and has a three year free replacement and 96 month pro rata warranty.
The engine does crank considerably faster with the new battery, even at -15ºF.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
01-29-2019, 04:53 PM
#23
Real Name: Jerod
Real Name: Jerod
Geez louise that thing is pricey though! I do agree, you get what you pay for in terms of batteries. After getting my Optima red top, I'm never going back to a lead acid battery ever again. AGM really is that much better and reliable.
01-29-2019, 08:35 PM
#24
I have a 3 year old ish Interstate from Costco. I've had no issues with it so far including starting my truck when it was -18 last saturday.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
01-30-2019, 01:36 AM
#25
I bought my runner in July of '16 (2000) and replaced the battery in it July of '17 and it was a duralast gold with a 5/07 manufactured sticker on it. Ended up getting a everstart from walmart because their made by Johnson controls. I've had no issues as far as extreme heat or extreme cold. Today was -20 all day and after 11 hrs of sitting outside it fired right up.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
01-30-2019, 03:18 AM
#26
Though pricey, this Odyssey's are amazing
Odyssey-Batteries-34R-PC1500T
https://www.amazon.com/Odyssey-Batte.../dp/B008FY5UF8
Really pissed I settled for the Optima Yellow Top instead of going with these. All I read about online is how Optima's quality went down.
Nothing but amazing reviews on the Odyssey
01-30-2019, 03:19 AM
#27
Thanks for all of the replies
I dont want to make too much of a big deal out of this- i always do anyhow. I called the local dealership today they told me what brand "their" Toyo badged Battery was but i forgot.. I believe that this is the 3rd battery since i bought the truck new in 97.
I do like that "X2" I've heard a lot about it from here and from other people. The Group size 34 AGM seems like a good way to go.. I'll look around again tomorrow.
Thanks again.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
02-03-2019, 08:17 PM
#30
Real Name: 3 Bears
Real Name: 3 Bears
Looking to get an odyssey, is this the one that requires a spacer ?
