Old 10-27-2024, 02:42 PM #31
Jonnyd511 Jonnyd511 is offline
Real Name: Jonny
Jonnyd511 is on a distinguished road
Real Name: Jonny
Originally Posted by Jonnyd511 View Post
My 97 sr5 is not starting, I originally thought it may have been a battery issue as I do have a tendency to leave a light on in the truck, so replaced battery, did not help, went through process of just updating all parts i.e starter, fuel pump, fuel filter, check all boots and coils for spark all are working, fuel is unobstructed though the filter, still just cranks until I would kill the power to crank anymore, I replaced all my relays in fuse box under the hood but I cannot seem to locate the other efi relay that is stated to be in the bottom of my interior fuse panel, I would like to see if anyone has an image as to what I'm missing or if I'm just gonna have to have a mechanic trace it like I did, so if any ideas of what or where I can take a different look at this would be awesome, thx
This is my only rig and really need to get this up and running today, please any info is appreciated
Jonnyd511 is offline   Reply With QuoteReply With Quote
Old 11-02-2024, 09:36 PM #32
DED&DED DED&DED is offline
DED&DED is on a distinguished road
My 1999 SR5 is slow to start also. most likely problem is ignition key/ignition lock wear. I. can't I to crank gently turning the key until I?hit the sweet spot and d=then it craNKS. "KIT TAKES A FW TRIES AND NWEWER KEYS HAVE LESS FAIL TO STARTS. JUST SAYING.
DED&DED is offline   Reply With QuoteReply With Quote
Old 11-04-2024, 12:27 PM #33
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Replace the ignition connector on the back of the key cylinder lock. Those contacts can wear out and the solenoid on the starter not getting 12 volt power to throw the solenoid in the starter. Or your starter contacts are warn out. Very common problem. :-)
key , pack , power , start , turn
1997 SR5 4x4 wont let my truck start 4Runnermex 3rd gen T4Rs 14 10-27-2015 10:18 PM
1997 warm start problems tobers 3rd gen T4Rs 6 07-08-2015 08:52 PM
1997 4runner turns over but wont start when hot. auggydoggy502 3rd gen T4Rs 3 05-11-2014 10:45 AM
1997 4runner turns over but wont start when hot auggydoggy502 Problems & Warranty Issues 0 05-10-2014 11:03 AM
1997 4Runner (3.4L V6) Warm Start Stall Problem? axhoaxho 3rd gen T4Rs 4 02-28-2006 07:14 PM
