Old 01-27-2019, 08:57 PM #1
powersandlorimer powersandlorimer is offline
powersandlorimer is on a distinguished road
1997 4runner won't start
Hi,
About 2 weeks ago it was 5° here, -10° with windchill. I had to move my truck, I turned the key once and nothing, the power worked but the engine didn't turn over. I turned the key again and I pumped the gas simultaneously and it started. I drove it for about 5 minutes. During this drive the engine was whirring almost like when you're low on power steering fluid... I didn't think too much of it, I just attributed it to extreme cold, especially since everything seemed to be fine prior to this.
I didn't move the car for 2 weeks after this. I went to move it yesterday and I turned the key and got no turn over, no clicking either, but the power worked.
Today it was much warmer 44°, I went back to the car with a multimeter and portable power pack. The battery metered at 12.29, I charged it for 10 min with the power pack and tried to start — nothing, same result. Then I took the pack off and kind of shoved the battery a bit to make sure it was seated properly, I also metered the battery again and it read 12.59 -- power pack was working. I then tried again, this time it actually made a small effort to turn over, but didn't quite start. Then I tried another turn of the key and back to nothing again.
I called a friend for a jump, I charged off their suv for 5 min, then tried to start up and nothing again.
I then tried 30min on the power pack and same result. I also checked my coolant reservoir and it was basically empty...not sure if this could effect the start up...
That's where I'm at. Looking for ideas. Thanks so much.
powersandlorimer is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 11:37 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
It sounds as if you may have a fuel issue. Can you hear the pump turn on?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 01:34 AM #3
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Possibly your starter. toward its end life it will work somethings and no others. you can smack it with a hammer a few times and try. sometimes that will make it work again but it would need to be replaced soon if thats your issue.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 09:07 AM #4
How do I check that? Is that just as simple as listening to the area where fuel is pumped when I turn the key? @LittleCaesar
Old 01-28-2019, 09:54 AM #5
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
lots of threads on this forum deal with similar issue. Here is one to get you started
99 won't start, no click
Old 01-28-2019, 10:06 AM #6
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
Checking the fuel pump...have someone turn the key to run while you have your ear in the filler cap...you get about 10 seconds of whine noise...kinda works...best way is taking off a fuel line...which I wouldn't recommend since you ask how to check it.
From what you're describing it sounds like the starter is not engaging and turning the engine to start it...sometimes if you leave the key in start you can hear a electrical whine noise...high pitch...my hearing is shot but that's one frequency I can hear still...hitting the starter while doing the key start will usually get it to go...then you know you need new contacts inside...cost like 8$...easy rebuild...to hit the starter you'll need a long extension or pipe to fit through the wheel well..pass side...tap the top part of the starter...look out for the big wire as it's full batt...its nice to have another person hit the key while you hit the starter but not necessarily needed...oh n it doesn't take much to get it to go so no splitting wood chops needed.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 10:30 AM #7
That is correct. Put your ear to the tank and have someone turn the key.
But if the starter is original, look there as well.
Old 01-28-2019, 11:04 AM #8
@WWRD99 I’ll give the tap on the starter a shot! Curious, do think the lack of coolant could be causing this?
Old 01-28-2019, 11:09 AM #9
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Sounds like your alternator has gone bad.
My wife's Rav4's alternator died. Had a really bad whine when running for about a day, then stopped powering the car altogether, which promptly drained the battery.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 11:26 AM #10
nissanh nissanh is offline
nissanh is a jewel in the rough nissanh is a jewel in the rough nissanh is a jewel in the rough
Cold weather and no start is a symptom of bad contacts. The low coolant is what bothers me. Try pulling all 6 plugs and inspect for a sign of coolant inside the cylinder. If there is no coolant, replace the starter contacts. Timmy the tool man has a great video about how to replace the starter contacts on a 4runner. Buy contacts from the dealer and it is about $15.
Old 01-28-2019, 12:08 PM #11
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Take battery out and get it tested.
Rule that out first.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 04:02 PM #12
@alumarine the multimeter reads 12.59, you think it could still be bad?
Old 01-28-2019, 05:06 PM #13
Those numbers are good but if you load test it and it passes you can move on to something else.
Old 01-28-2019, 05:34 PM #14
You need to be able to check the cold cranking amps to see if it has enough derriere to kick over the starter.
Yesterday I had a neighbor who had a no crank symptom. The battery was at 12.6 volts but the cold cranking power was only at 150 out of a possible 650 amps. Only a new battery solved her dilemma.
Old 01-28-2019, 05:48 PM #15
Would one of these $20 harbor freight 100amp load testers do the trick? @LittleCaesar
key , pack , power , start , turn
1997 SR5 4x4 wont let my truck start 4Runnermex 3rd gen T4Rs 14 10-27-2015 10:18 PM
1997 warm start problems tobers 3rd gen T4Rs 6 07-08-2015 08:52 PM
1997 4runner turns over but wont start when hot. auggydoggy502 3rd gen T4Rs 3 05-11-2014 10:45 AM
1997 4runner turns over but wont start when hot auggydoggy502 Problems & Warranty Issues 0 05-10-2014 11:03 AM
1997 4Runner (3.4L V6) Warm Start Stall Problem? axhoaxho 3rd gen T4Rs 4 02-28-2006 07:14 PM
