01-28-2019, 05:56 PM
Real Name: Jake
Real Name: Jake
Are these front lower control arm bushings bad?
I had just finished installing new O2 sensors and had a look around under my engine, just to see if there were any leaks or oddities that I could remedy. I say these bushings with cracks...
Do these need replacing??
Passenger side
drivers side
I'm going to go have a look at my rear bushings now...
https://i.imgur.com/WQdryKXm.jpg
The Sequel - 1996 4Runner SR5 - Houston, TX
The Original - 2001 4runner SR5 - SOLD
Etsy Page - Custom Pinstriping and Sign Making
@8LinePinstripe: Instagram
01-28-2019, 07:23 PM
Yeah, those are done
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
01-28-2019, 07:52 PM
Real Name: Mark
Real Name: Mark
yep they done, have a sawz-al with 6" blades nearby bet you need it with rust I see.
01-28-2019, 08:23 PM
Real Name: Jake
Real Name: Jake
dam.
any recomendations for replacements? or is this an OEM only sort of thing...?
01-28-2019, 08:40 PM
Real Name: Mark
Real Name: Mark
Oh boy can o worms asking that?
Been happy with OEM, I hear think it's whiteline white something are popular.
Ban me mentioning Moog have held up good on other rides, stay away from other aftermarket chit.
01-28-2019, 08:54 PM
Real Name: Instagram: briansd_97r
Can you tell just by looking? I was told you cannot and that a simple visual is not how to tell if lower LCA bushings need replacing.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
01-28-2019, 09:00 PM
Real Name: Jake
Real Name: Jake
thats what I thought too, I pry'd around with a flathead and there wasnt alot of movement, but the weight of the car might mitigate any movement.
01-28-2019, 09:03 PM
Real Name: Mark
Real Name: Mark
@ BrianSD_42
, Will agree with that, But the cracks do mean something wouldn't you say.
Not a oh shit moment, get ready.
Edit: would you say correct way is to seperate LBJ swing arm up and down see what ya got.
01-28-2019, 09:07 PM
Real Name: Steve
Real Name: Steve
Looks like mud not rust.
01-28-2019, 09:17 PM
Real Name: Mark
Real Name: Mark
Look past the mud, looks like rust in cam bolt threads other places also.
Doesn't take much to freeze sleeve to bolt mine had no rust or mud a sawzall
was needed just warning Lamer of what could be.
01-28-2019, 09:19 PM
You can guess by looking. You can tell by doing a simple test.
Get under the car with both wheels on the ground. Start the truck and have someone turn lock to lock. Look at all 4 bushings. If there's more then 1/8" of play they're bad. I just did mine two weeks ago. Visually they looked fine but both passenger and driver front had almost 3/8" play.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
01-28-2019, 09:21 PM
If they’ve never been replace then they are probably due along with most other rubber bushings in these vehicles. I had a shop replace mine last year and they used MOOG, they tore within the year so I replaced those with Whiteline.
01-29-2019, 12:29 AM
Real Name: Jake
Real Name: Jake
@ BrianSD_42
thats what I thinking of doing to test them out. but I had a look at my rear control arms and those bushings look very worn. So now I may just do the fronts and rears all at once. Whiteline or Energy Suspension for the fronts, and Energy Suspension for the rears.
I concur, I weny under and brushed most of that crap away, doesnt look too bad.
I went under again and was able to brush that off. but I will have the means necessary to remove them should I need it.
I might do this before taking them off just so I can compaRe to the new ones.
They are the original bushings with 260k miles. probably due for a change.
01-29-2019, 09:46 AM
Whiteline for the front will be easier since you don’t have to re-use the inner sleeve like you do on the Energy Suspension ones. Rears, I’m not sure, I just put SPC arms in because they are stronger and I didn’t have to deal with replacing bushings.
01-29-2019, 10:49 AM
Real Name: Jake
Real Name: Jake
from what I have seen, if you have enough heat on the front control arm around the bushing, you can "melt" the rubberized connection to the outer sleeve and push the rubber out. followed by some clean up of course. But it doesn't sound too hard.
