Old 04-25-2019, 06:06 PM #16
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all
Real Name: Jerod
Originally Posted by JRZEE2000TR4LTD View Post
I forget the brand but it had all the same exact casting marks as my OEM caliper.
Most companies only sell OEM reman'd calipers. So if you order Powerstop, Calihan, NAPA, etc. they are all the same OEM Toyota calipers, very few companies have reverse engineered a caliper and made their own, I'm yet to see one for our 4Runners. Where it differs between companies is the quality of the aftermarket seals and components installed in them.
I'm going on 4 years with my Powerstop calipers with no issue.
@4Runner4Leon try re-bedding your brakes. When I installed my rotors, I went on some "spirited" drives and heated up my brakes big time. I thought I had warped them but realize that the pad material wasn't evenly distributed on the rotor, I could see it. I did another brake bedding proceduce and the wobble went away.
If that doesn't do it, just have them turned at a machine shop for cheap.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 04-26-2019, 08:38 AM #17
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light
Real Name: Leon
Thanks, I'll give that a shot. I bedded them in per the instructions, and they were fine for a while. Just recently I noticed the chatter again. I'll try the procedure again.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 Springs | B&M 70264 Trans Cooler | GlowShift Trans Temp Gauge | OEDRO LED Bulbs | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 05:43 PM #18
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
Pedal Feel?
This is a little off-topic, but with the 199 upgrade does it change the pedal feel at all? I keep getting inconsistent info. If you go with the 199 and bleed your brakes properly or have a shop bleed them does the pedal travel or feel change (and is it noticeably obvious) with the 199 upgrade?
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
Ser1clymb is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 05:48 PM #19
JMat's Avatar
JMat JMat is offline
JMat is on a distinguished road
JMat's Avatar
It didn't change te pedal feel for me at all... That's why I stayed away from the 231mm upgrade. My '98 brakes great now.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 03:41 PM #20
RockHead MA RockHead MA is offline
RockHead MA is on a distinguished road
I just installed the 199 Centric Posi-Quiet calipers and Centric premium rotors yesterday
https://www.rockauto.com/en/catalog/...b,caliper,1704
I've been pleased with Centric stuff on my other cars, so I expect I'll be happy with them on the 4Runner. I like the coated hub & edge on the rotors, and they've run straight. Unfortunately I broke a corroded hard brake line, so my rig is still on stands. Hopefully, get to that tomorrow. It's probably drained the master cylinder while it's been sitting, that will add to the fun.
Originally Posted by marthe4runnerguy View Post
True that's my fault , here is the correct link
2001 TOYOTA TUNDRA 4.7L V8 Caliper, Rotor & Brake Pad Kit | RockAuto
RockHead MA is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 06:57 PM #21
Ruiner's Avatar
Ruiner Ruiner is offline
Ruiner is on a distinguished road
Ruiner's Avatar
i used those 20% off coupons that Advance Auto always has and bought the calipers/pads/rotors all from there. no issues and pretty cheap.
Ruiner is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 07:35 PM #22
fastone53w fastone53w is offline
fastone53w is on a distinguished road
I just did the 199 brake upgrade on my 2002 4runner,. Got all the parts from O-Reillys auto parts.
The 199 upgrade was not too bad to do myself, bleed them as normal.
I really like them on truck, took boat for tow for last time for the season and could tell the bigger brakes where on. Very happy, had to do no mods to truck or rims, just out of the boxes and bolt on.
I just bought my 2002 4runner v6 4x4 used. Needed a tow vehicle for my boat and other toys, ice fishing, and hunting.
Been very happy with it. My first Toyota, for 270000 miles on it. Cant believe how nice driving truck it still is with all the miles on it!
Just makes me wonder what a new one must drive like...
Last owner did take very good care of it.
It drives circle around my old ford f150 that died at about 170000 went thru 3 engines and 2 rear ends, what a piece of crap that was. I bought it new and nothing but failures and dealership trying to avoid every warranty issue.. made me give up on owning American cars and trucks.
since for last 10 years had 2 Subaru cars first one went 289000 timing belt took it out, second one is at 240000 and still going strong.
My tow vehicle was a 99 AWD chevy astro van that made it till 179000 and rusted frame took it out in June.
Really happy with my Toyota 4runner!!!
fastone53w is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 07:41 PM #23
Silver Supra's Avatar
Silver Supra Silver Supra is offline
Silver Supra will become famous soon enough Silver Supra will become famous soon enough
I got the power stop Z36 kit off amazon. Works great.
Silver Supra is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 09:11 PM #24
xcmtb83 xcmtb83 is offline
xcmtb83 is on a distinguished road
Originally Posted by 19963.4lsr5 View Post
I must ask.
What is the rotor size and brake pad size difference between the factory 3gen and the smaller 199 braking system?
Also what is the caliper piston diameter of the OEM 3rd gen, the 199 (45mm I think), and the 231mm?
Tonight I just confirmed by measuring, the 199mm and the 231mm calipers have the same size pistons, 45.36mm diameter.
Active Fleet
1996 SX V6 MT 4x4 Regular Cab Tacoma, 1999 TRD V6 MT 4x4 Extended Cab Tacoma, 1996 SR5 V6 AT 4x4 4Runner
Decommissioned With Honors (Toyota Frame-Rust Buyback)
1996 4CYL MT 4x4 Regular Cab Tacoma
xcmtb83 is offline   Reply With QuoteReply With Quote
junk , kit , power , throwing , trash
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Did tundra brake upgrade and brake pedal mushy. 3rdgenfan 3rd gen T4Rs 5 10-25-2015 08:51 PM
is Tundra brake Upgrade = Sequoia brake Upgrade??? infamousRNR 3rd gen T4Rs 11 02-20-2014 05:22 AM
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 8 06-22-2012 01:52 AM
