Old 10-27-2019, 06:58 PM #1
Godog45's Avatar
Godog45 Godog45 is offline
Godog45 is on a distinguished road
Godog45's Avatar
2000 limited, trouble engaging 4wd with button
Hi, i have year 2000 ,limited ,having trouble with the button on the 4W lever. that engages to H4 {Unlocked ] i have 239K on the car and i am the second owner.
it recently having difficulty engaging H4 with the button on pavement unless you stop and put it in reverse it will not engage . when the light blinks ,the steering wheel will feel heavy and car pulls left. you must stop and put car in reverse .then it will work normal ,also sometimes will hear a thud
the H4L lever {IN locked position}
works fine . i only have trouble with the button, with the unlocked position
any suggestions whats wrong and what it needs to work properly again?
Godog45 is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 11:28 PM #2
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Fix
I had a similar issue and replacing the transfer case fluid was the fix. Some people forget to change it and when it is old all type of engagement issues can happen
Thebeastlives is offline   Reply With QuoteReply With Quote
button , car , put , stop , unlocked
2000 Limited Factory Alarm Trouble... HammerTime 3rd gen T4Rs 5 04-17-2023 08:40 PM
AOB Switch Illumination Issue QUESTION/Trouble With Switch Fully Engaging FIX mbumpus11 5th gen T4Rs 11 10-23-2021 03:51 PM
2000 limited, trouble engaging 4wd with button Godog45 3rd gen T4Rs 0 10-27-2019 05:14 PM
02 having trouble engaging 4 wheel drive MJW 3rd gen T4Rs 7 09-19-2012 12:02 PM
Engaging 4WD on v6 '05 Limited: rgcary 4th Gen T4Rs 7 03-10-2011 07:50 PM
