01-30-2019, 08:41 AM
What is everyone using for the 199 brake upgrade?
I've had a set of 199 calipers/rotors from Napa for a couple of years and both fronts are nearly frozen. With the tire off the ground I can barely turn one by hand, the other I cannot.
I'm thinking of just throwing them in the trash and going with a power stop kit, but wanted to see what everyone else is using?
I don't have time to rummage through a junk yard and want brakes that just work.
Thanks!
01-30-2019, 09:38 AM
Real Name: Alex
Real Name: Alex
I went with the 199 power stop kit. Ordered from RockAuto and sent them my old original calipers as a core.
They have been great for me and everything seemed high quality. Only issue I had was the pad retaining clip broke on the driver side causing the pad to rattle. Replaced it and haven't had the problem again.
You could rebuild the ones you have if youre looking for a little project. Might be worth it if they are OEM.
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
01-30-2019, 11:07 AM
Real Name: Leon
Real Name: Leon
I didn't want red calipers, so I bought Cardone Ultra Premium calipers from RockAuto (powder coated in gray), and the Power Stop rotors and Z36 pads, also from RockAuto. I'm happy with the setup so far.
Interesting factoid is that it was significantly cheaper to order Power Stop calipers, rotors, and pads from RockAuto separately than as one complete kit, at least at that time.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
01-30-2019, 03:04 PM
I bought mine from Napa too and am starting to have the same issue... I can still turn the wheels but it's not easy.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
01-30-2019, 06:36 PM
Thanks!
I just commute on pavement in my 3rd gen so I have the basic Power Stop rotors and some auto zone gold ceramic pads, 20k miles later and everything is still perfect. Just ordered a power stop kit for my other 3rd gen, so a Power stop kit is definitely a good option
01-30-2019, 10:36 PM
I ended up ordering a Power Stop 231 kit today and will be tossing my NAPA garbage in the the... well... garbage.
01-30-2019, 11:43 PM
Real Name: Jonathan
Real Name: Jonathan
Could you share the link of the items you ordered please?
Thanks bud.
1999 Hilux Surf SSRX- Two Tone White/Bluish Met. Silver |50,000 Miles|
Dedicated Studded Winter 285/75/16 Duratracs, Unknown JAWA Rims?, JAOS Skid, Satoshi Mod, 3" Lift (TBD), Kenwood DPX U77 + Subwoofer
01-31-2019, 12:08 AM
Thanks bud.
https://www.rockauto.com/en/catalog/...+pad+kit,14204
3 options right there from basic to heavy duty, these kits include calipers too if yours are gargage rn
01-31-2019, 12:43 PM
Im sure there is guys on here that would love to get some used napa 199 calipers/rotors, especially since its prob guaranteed for life.
Offer them up for free on the forums. I have the 231 napa's and while I haven't checked if I can freely spin them with my hands. My mileage has been the same over the 30k + miles I've had them.
01-31-2019, 03:19 PM
Originally Posted by marthe4runnerguy
That's a link to regular 4Runner brake parts, just FYI. The OP (and others) are interested in the Tundra upgrade parts.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
01-31-2019, 07:10 PM
True that's my fault , here is the correct link
2001 TOYOTA TUNDRA 4.7L V8 Caliper, Rotor & Brake Pad Kit | RockAuto
04-24-2019, 04:43 PM
How have the cardone calipers held up so far?
04-25-2019, 03:39 AM
Real Name: Leon
Real Name: Leon
The calipers have been just fine so far. Can't say the same about the rotors, they're pulsing again under hard braking just like the original 4runner rotors did, ugh.
04-25-2019, 07:31 AM
Real Name: John
Real Name: John
I have the 199 calipers. OEM. Got them used from a forum member a while back. I rebuilt them with OEM seal kits and new OEM pistons. I ran them for a while then one of them started to hang up. Took the suspect one apart and found it to be rusty right on the edge underneath the dust seal. Cleaned it up. Lightly honed the bore edge. Painted the metal right to the edge. Again used new OEM seals. Had the same problem about 6 months later. I'm willing to bet that most of the people who have this problem are in "rusty" environments or are fording a lot of water with their trucks. I just replaced that caliper last month. I forget the brand but it had all the same exact casting marks as my OEM caliper. I would think that most of the calipers out there are OEM castings probably with AM pistons and seals of varying quality. We'll see how these hold up.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
04-25-2019, 03:22 PM
I must ask.
What is the rotor size and brake pad size difference between the factory 3gen and the smaller 199 braking system?
Also what is the caliper piston diameter of the OEM 3rd gen, the 199 (45mm I think), and the 231mm?
