Originally Posted by Dezert4Runner
Check your LCA cam bolts, if you loosened those at all they’ll clunk like that. Firestone did an alignment years ago and left one side loose and it clunked like that. I just did some front end work a couple weeks ago and I forgot to tighten the passenger side LCA cam bolts and heard a clunk and knew exactly what to check this time.
I didn't loosen them, Is it possible they may have loosened when I pressed down (by stepping on it with the UCA disconnected) on the lca to get the coilovers in? I ended up having to shorten the coilovers a bit since they were too long to fit nicely.
