01-30-2019, 03:02 PM
Lift Gate Support Strong-arm vs OEM issues
I figured a detailed photo is always helpful to somebody in the future who is replacing the back liftgate supports. Searching this forum I found useful information on getting spacers and washers to fit between the connection brackets. Problem I ran into was the difference in the top ends of OEM and StrongArm. The existing pin is made to seat into a square hole and won't work with the holes in the aftermarket one. And even if I was able to make a square hole in the new support, the bracket metal is thicker so the pin won't quite clear enough to put on a c-clip. Sooooooo....looks Like I've got to find a new bolt/pin of correct length to get through the hole and allow a c-clip.
01-30-2019, 03:22 PM
I need to replace mine as well so I went to Amazon to look for options. The strongArm link below shows that the ends are very similar to OEM and will fit,. at least to my untrained eye. If they sent you a set with that silver end on it, I'd send it back and insist on ones that look like the Amazon picture. Maybe they sold you old stock, or a mistake?
https://www.amazon.com/StrongArm-428.../dp/B000ALBROC
02 Thundercloud Sport, 155k.
01-30-2019, 03:51 PM
Wow, just looked at that pix and you're right.
01-30-2019, 04:49 PM
Yea I can verify the strong arm’s that I got had the square hole and fit fine for me. Looks like they sent you the wrong thing.
01-30-2019, 04:50 PM
Thanks for catching that. I called the company on the shipping slip and they said they know that there is a batch of 4286 Strong Arm lift arms they are having to send back to the manufacturer. I said I still need to buy some and they said don't order from the same Amazon source but places like AutoZone can get them. Just to make sure that the other sources aren't buying them through them at AMS Automotive. At least now I know what to look for if I find more.
01-30-2019, 09:48 PM
Real Name: Rich
Real Name: Rich
I used the Monroe 901446 Max-Lift set back in April of 2017, they go up like a monster so I gotta watch my head, they have the correct square end to use the old bolt to mount it. I got mine on Amazon for 18 each. I see advance auto carries the strong arm for 35 each plus a discount if you order online. I'm not sure why they are double the price from the ones I got. Is the warranty better I wonder...side note these don't open as strong today as it's 6 degrees out but once it warms up it opens fine...maybe the strongarm ones don't vary on temp.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
01-30-2019, 10:34 PM
Real Name: keith and jenny
Since it has been ridiculously cold in some areas recently, I would be interested to hear from people in those areas how the strong-arm supports are doing in those conditions.
01-31-2019, 12:17 AM
Supposedly strongarm has a ‘cold spec’ version and a regular version.
01-31-2019, 01:32 AM
Real Name: Leon
Real Name: Leon
Strongarm 6815 is the strong version. I have a set of those in my truck, and they are amazing - the liftgate pops right up.
Oddly, while they were available last year on Amazon for about the same price as the regular strength 4286 units, they are now very hard to find at anything other than ridiculous prices. Not sure why.
https://www.amazon.com/4Runner-Liftg.../dp/B00W8QBA30
Qty (2) Toyota 4Runner 1996 To 2002 Liftgate Lift Supports (Added Lifting Force) 719926120722 | eBay
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
01-31-2019, 02:29 AM
Real Name: Keith
Real Name: Keith
Could it be the old 'jack up the prices during the winter when most owners will become annoyed at how slow their original OEM are opening the liftgate' trick?
01-31-2019, 11:24 AM
Real Name: Mark
Real Name: Mark
Originally Posted by greeney
Thanks for catching that. AutoZone can get them..
Bought Strongarm's regular duty last year, matched perfect. Rockauto is cheaper than most places.
01-31-2019, 11:55 AM
5°F today. My 6815s still pop it all the way up which the factory ones didn't do new.
EDIT: Last few inches were slower than usual just now, but it still went all the way up.
My Backyard Frame Swap
01-31-2019, 11:58 AM
I installed the regular duty strong arms a few days ago (didn't know there was a better version) and was pretty disappointed. From what I had read I thought they would have no issue going all the way up, I was wrong. granted we've been on either side of 0 degrees here for the last week or so but I am still unsatisfied. At least they hold it up though, not more lift gate smashing down behind me.
*edit* they lift up to about the last foot, if I lift it the rest of the way by hand it will stay in position. No doubt they will do a fine job once this cold snaps.
01-31-2019, 01:47 PM
Real Name: Leon
Real Name: Leon
That's exactly the experience I had with the regular 4286's, so after clunking my head one time too many, I switched to the 6815's.
01-31-2019, 06:56 PM
Regarding wrong item that was sent:
Not to beat this to death, but seller wants pictures and more explanation before processing my refund or exchange. This whole third party thing with Amazon is nuts, with 3 layers of distributors and China somewhere at the end. Made this detailed explanation pix. Sigh.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
