Old 09-01-2019, 11:16 AM #31
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
The 4 banger has so much more room in the engine bay than the V6. I just did a head gasket replacement on an overheated V6 only find out the rings on a couple cylinders were destroyed. Looked fine visually. The new long block should last for many years though.
How is the power difference between the 4 and the 6? Torque difference?
Nice build!
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 12:59 PM #32
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
I had a engine with light scoring on cylinder wall pulled the pistons reringed homed the block it turned out great
plcfcng is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 10:59 PM #33
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Nice build!
This will be my first 4 cylinder automatic experience with larger than stock tires. The RZ motor is my choice out of the two hands down. The difference in power just does not justify the drawbacks of the V6.
I know a lot of people sing the praises of the 5vz, but I just don't see it, sure it's reliable, but doing even minor repairs is a nightmare since the dohc design makes it a snug fit into the bay, also not a fan of the front accessory drive, timing and oil pump setup. The later 2GR 4.0 is a much more refined design.
As far as power and drivability goes, I've had experience with both motors in lots of platforms, they drive very similarly, the 3RZ in my opinion gets a bad rep solely because of the highway gears they were paired with in most applications, most notably the standard cab 4x4 early Tacomas that got the 3.48 gears. Of course a v6 truck with 4.10s will outrun that.
I'd swap/R&R 5 RZ motors before I touched a 3.4, especially coupled to an auto. Fingers crossed my 270k mile bottom end holds up for at least a few more miles.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 11:03 PM #34
UnderFire's Avatar
UnderFire's Avatar
Question: what do you do when you've got a vehicle that doesn't run.
Well, you swap in a minty dash and a new head unit of course. Well, that's what I do at least. Interior still needs a bit of love to get it up to snuff, one piece at a time.
I've yet to decide if this slightly beat Grip Royal Mahogany wheel is good enough for this thing yet. Maybe it deserves nicer, or maybe it's too nice, we will have to wait and see I guess.
Old 09-02-2019, 09:12 AM #35
jross20's Avatar
jross20 jross20 is online now
jross20 will become famous soon enough
jross20's Avatar
Upper and lower ball joints if you haven't already. Some guy just recently posted about a catastrophic failure.
jross20 is online now   Reply With QuoteReply With Quote
Old 09-02-2019, 02:47 PM #36
UnderFire's Avatar
UnderFire's Avatar
Oh I know lol. Just had a buddy have a failure on his Tacoma. Trying to hold out until I can find a set of manual hub spindles for the front and go through everything all at once.
Old 09-12-2019, 02:15 PM #37
UnderFire's Avatar
UnderFire's Avatar
Today's the day. Got it running a couple days ago, dialed in over the last couple nights and it's now good enough to give it a shot. Running a little rough at low RPM, had the same issue with my Tacoma I rescued and it went away with time so we'll see. Off to the DMV, its back on the road.
Old 09-14-2019, 06:01 PM #38
UnderFire's Avatar
UnderFire's Avatar
Getting the quirks all worked out. She's running at the perfect temperature no issues there. Transmission was a little lazy the first couple times out but I've finally got it topped up just right and she's shifting really nicely now. The ECU threw a code for the O2 sensor so I went ahead and swapped it out. Now my idle is going down below 1k and she purrs like a kitten.
Still on the mechanical to-do list is a new set of front brakes, they're causing some pulling and wobbling. There's quite a bit of crusty rust built up on the slide pins, along with the rotors not looking hot. Gotta get the rear drums off for a checkup and adjustment too. The passenger CV already puked a bit but no tears yet.
On a very happy side note, I did the math yesterday to confirm my suspicion. The Auto 4X4 3RZ did come with 4.56 gears. At least in my case. It drives great with the 33's very happy. Need to make a trip to the junkyards and hopefully piece together the interior a bit better, and with any luck I'll stumble across a clean black hatch sometime soon.
Old 09-14-2019, 06:29 PM #39
Smitdog's Avatar
Smitdog Smitdog is offline
Smitdog is on a distinguished road
Smitdog's Avatar
Great build! I just picked up my first 4runner,it's an 02 SR5 4x4,has 154xxx on the clock. It had a bad motor, I bought a crate 3.4 v6 from Kar King auto. It is currently at the mechanic getting a transplant lol. Leather interior too. Kinda weird to love a vehicle this much and only drove it 5 miles to the shop lol. I didn't get the deal you did but I'm happy with the price picked it up for $1500
Sent from my moto e5 supra using Tapatalk
Smitdog is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 06:31 PM #40
Smitdog's Avatar
Smitdog's Avatar
Once she is running gotta take a trip to the body shop to get the 3M stick on bug shield offSaved from the Scrapyard: Ressurecting a 500$ 3rd Gen
Old 09-14-2019, 09:35 PM #41
UnderFire's Avatar
UnderFire's Avatar
Looks like you got a hell of a deal to me, post-face-lift, nice color, straight body and a mint interior. All that and only 150k on the clock. My high mile base model doesn't hold a candle to that value wise.
Old 09-15-2019, 08:52 AM #42
Crowcifier6 Crowcifier6 is offline
Real Name: James
Crowcifier6 is on a distinguished road
Real Name: James
Originally Posted by UnderFire View Post
...On a very happy side note, I did the math yesterday to confirm my suspicion. The Auto 4X4 3RZ did come with 4.56 gears....
I recently discovered this lately as well.....a friend told me it was desirable. So basically, these are geared lower and will have less problems running larger tires?
Our rigs are very similar, I have a black 98 base model 3RZ auto as well.
Looking forward to the progress.
98 Base Model 2.7L
Crowcifier6 is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 01:10 PM #43
UnderFire's Avatar
UnderFire's Avatar
In simple terms yes, having a lower final drive ratio puts the engine at a mechanical advantage and allow torque to be sent to the wheels more efficiently. With out high strung 4 cylinders this also allows us to stay in the powerband more effectively.
To give you an idea of how big of a difference it really makes, this Runner with the 33" tall tires on it sits just about 2,000 RPM at 60 MPH. My Tacoma has the same transmission and 4.10's with 35" tires, at 60 MPH you're around 1600 RPM.
Old 09-15-2019, 02:28 PM #44
Real Name: James
Real Name: James
Cool, so I take it the power band is somewhere within 1500-3k? Is your Taco 4 cyl?
98 Base Model 2.7L
Old 09-15-2019, 02:33 PM #45
UnderFire's Avatar
UnderFire's Avatar
Most of the power is between 3 and 5k I'd say. My Tacoma's V6 powered (unfortunatly.)
500$ , bought , interior , miles , scrapyard
I just saved 35k wrpsuite 3rd gen T4Rs 14 12-10-2018 01:48 AM
VSC Saved Me Whiplash Willy 5th gen T4Rs 28 12-28-2013 03:35 AM
Saved my stepdads a$$ gigerunner All Other Vehicles 0 12-08-2013 12:14 PM
Saved By the Nav. Koz Engines / Suspension / Wheels / Tires / Audio / Accessories 6 07-28-2006 08:32 AM
ABS saved my a$$ greentoy 3rd gen T4Rs 6 02-10-2006 05:54 PM
