Old 02-01-2019, 11:38 PM #1
pstur11 pstur11 is offline
pstur11 is on a distinguished road
Post engine stutter and hiccuping idle
2001 4Runner with 170k miles. Symptoms starting with small hiccups during idle, like one of the cylinders was missing a fire. At that point I ran a can of sea foam through the gas tank. Then, more recently, during acceleration with a cold engine the engine significantly lagged to accelerate, like it was missing many times in a row. This issue seems to be more significant when the engine is cold. I've owned the 4Runner for 30k miles, and the spark plugs and wires were last changed at 132k miles. No check engine light is on.
Any ideas on where to begin trying to diagnose and fix this issue? Thanks for the help.
pstur11 is offline   Reply With QuoteReply With Quote
Old 02-02-2019, 02:22 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Sounds like a coil is starting to intermittedly fail. Any CEL codes set or pending? That would help isolate the particular coil then you could swap one with another to verify if the codes switch cylinders or simply test each coil, one is likely weak. Don't overlook the wires even though somewhat new.
Luck.
2001 Limited 4WD - 340+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 02-02-2019, 11:41 AM #3
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
Have you done a full clean up of the intake, TB and its sensors since you got it?
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 02-02-2019, 09:02 PM #4
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
I'd look at coils, wires and spark plugs first. Check coil and spark plug boots for oil contamination due to leaking spark plug tube seals in the valve covers. Check the inside of the boots and the spark plug insulators for carbon tracks, dark lines that won't rub off the spark plug's insulator that build up over time and allow the spark energy to arc out into the body of the spark plug or the spark plugs tube. I find that a lot on Toyota trucks. If you have cylinder misfire codes focus on that cylinder first.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 02-02-2019, 11:27 PM #5
stecow's Avatar
stecow stecow is offline
stecow is on a distinguished road
stecow's Avatar
Let us know what happens and what you did to solve the problem.
I've got a similar thing going on that I've been trying to pinpoint. With a colder engine I have slower acceleration, particularly in 2nd gear its most noticable to me. I'll shift into 2nd and accelerate, it'll have a bit of power at first but then tapers off as I give it more gas.
1998 SR5 Tacoma 4X4 with a manual 3.4L - Rolled and TOTALED
1998 SR5 4Runner 4X4 with a manual 3.4L and rear locker
Current 2011 4Runner SR5
stecow is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 12:41 PM #6
SoCalDucky SoCalDucky is offline
SoCalDucky is on a distinguished road
Any update? I have been experiencing the same thing while stopped at a light (Intermittently) or while on the freeway while accelerating from 50-60mph. Never happens during street driving tho?
SoCalDucky is offline   Reply With QuoteReply With Quote
Old 02-04-2019, 01:09 PM #7
Thanks for all of the feedback everyone! Update: pending P0302 Cylinder 2 Misfire Detected. Next steps are to first follow recommendations of MaineRunna and jgue467.... due an inspection to look for oil contamination and then switch the coil from cylinder 2 with another cylinder to see if the misfire stays with the coil or cylinder, and if it stays with the cylinder then try switching the spark plugs around.
Old 02-04-2019, 01:11 PM #8
Never! In general, what are the symptoms of these items being dirty?
Old 09-16-2023, 07:10 PM #9
velomatt's Avatar
velomatt velomatt is offline
velomatt is on a distinguished road
velomatt's Avatar
Had a similar problem. Misfire code. I replaced plug on the indicated cylinder and the hesitance is gone. I still get little hiccups on idle. No codes.
01' T4R SR-5 Dorado Gold, Sunroof Delete, 99' Black Mirrors, 02' Black Door Handles, Bushwacker Fender Flairs SPC UCA, Toy-Tec BOSS w/Superflex Rears, Shrockworks Front Bumper and Sliders, 4Crawler 1" Body Lift (Poly), Whitson Full-Length Roof Rack, Tepui Ayer Tent
PIAA Driving & Fog lights.
Dual Odyssey Batteries, Alpine W505, 3-PDX Amps, Dayton Audio 10" Sub in a JL Stealth Box, Seas Tweeters
5th gen TRD-Pro wheels, 265-70-17 BFG-KO, Stop Tech 13WL Brake Upgrade, Hayden Bi-pass Tranny Cooler
velomatt is offline   Reply With QuoteReply With Quote
cold , engine , issue , miles , missing
Rough Idle, Engine Sputtering, Engine Ticking, Flashing CEL Sotovo 3rd gen T4Rs 29 04-18-2016 10:35 PM
1997 4runner, 3.4l: idle speed too low, engine stalls at idle werminghausen 3rd gen T4Rs 11 09-01-2015 01:03 AM
stutter in engine when letting off the gas indaclear 4th Gen T4Rs 2 08-31-2015 12:14 PM
2200 rpm engine stutter??? WHY??? dragonflyfreak121 Classic T4Rs 3 07-20-2011 11:51 PM
V8 Engine Idle cwyoungb Problems & Warranty Issues 3 11-10-2008 05:24 PM
