Old 02-03-2019, 07:15 PM #1
Jungoes's Avatar
Jungoes Jungoes is offline
Jungoes is on a distinguished road
Jungoes's Avatar
DIY Climate Controller Repair -How to
So finally after some time I figured this out, and before I begin I KNOW there are users here charging for this service that do not openly share the steps on how to do this.
This really pisses me off because had it not been for the sharing of knowledge on this site I would not be a 4 runner owner.
Anyway If you can install a car stereo or upgrade a brake caliper you CAN do this.
Special thanks to @Wishmun for the pictures as I did not take photos when i did mines and he was kind enough to take the pics when i sent him the instructions.
Anyway the repair is for the following known issues with the HVAC climate controller found on 2000 or newer units.
Common issues:
1. Sticky buttons, erratic display or no control feedback after pressing the buttons.
2. Pressing the centre of the unit and then getting some of the buttons to work.
this write-up will not address any issues with the temp or fan speed control dials due to worn out potentiometers - if you are getting problems with these - change them, you can get them working with some electrical contact cleaner.
Instructions:
1. Remove climate controller from dashboard
2. Disassemble the unit into the two parts- remove outer housing- there are 2 yes 2 boards inside the unit.
3. CAREFULLY disconnect the ribbon cable separating the 2 boards, do not bend or tear these ribbon cables. There is a white clip to move before pulling the ribbons from the sockets.
4. Cut the plastic housing that holds the LCD panel as shown below.
5. Remove the white plastic box to access the solder connections behind the lcd panel.
6.TIP: you can bend the pins from the LCD panel that feeds to the board using a pencil/ pen to allow the rods to bend over a curved surface- ONLY BEND TO ALLOW soldering access.
7. Use a clean soldering iron and gently touch up all the solder connections on the board EXCEPT the Main IC chip that is in the centre. (I only labelled a few spots that are typical on the board)
8. Can't stress it enough- DO NOT LET solder get on the connections on the main chip. ( Ask me how hahah)
9. Re- assemble and enjoy!
This is what worked for me, I don't recommend changing any of the buttons ( mini switches) as I changed mines and that was not the problem.
Pictures below and credits to user @Wishmun :
DIY Climate Controller Repair -How to-image-1-1-jpg  DIY Climate Controller Repair -How to-image-1-2-jpg  DIY Climate Controller Repair -How to-image-2-jpg
2000 Limited, 2021 SR5
Jungoes is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 07:41 PM #2
Billy00NC Billy00NC is offline
Billy00NC is on a distinguished road
Red face Thanks Jungoes & Wishmun!
If the Superbowl wasn't on right now, I'd be tearing down the console to get to my flaky control panel.
I appreciate sharing this information.
I'd also recommend attempting to perform the "DTC Diagnostic Test Mode" as listed in Section DI-578 through DI-582 of the Toyota repair manual before performing this solder fix. There's a fuse that can be pulled to reset the system, plus error codes that point to systems external to the control panel. I haven't tried the DTC test yet, but in my case I don't think the test will run.
If no one else shares the DTC "how to", I'll try to add it here later.
I'll also post whether or not I succeeded.
Billy00NC is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 11:35 AM #3
Jungoes's Avatar
Jungoes's Avatar
Thanks for the reminder @Billy00NC
I did that check before attempting my repair but couldn't get the two switches " AUTO " and R/F to stay on and enter the DTC procedure. The R/F switch is the one that had the short for me to start with.
Pages you referenced are shown below for anyone wanting to try this before
attempting the re-soldering.
DIY Climate Controller Repair -How to-dtc-578-jpg
DIY Climate Controller Repair -How to-dtc-579-jpg
Old 05-29-2019, 08:38 AM #4
4runn34's Avatar
4runn34 4runn34 is offline
Real Name: Justin
4runn34 is on a distinguished road
4runn34's Avatar
Real Name: Justin
Thanks to the both of you for posting this. I'm going to try out the diagnostics procedure tonight. I just bought my 99 Limited 4Runner and the AC worked when I bought it but days later stopped working. Also noticed some of the switches intermittently respond on the HVAC panel. I did a recharge and still nothing. The condenser cycles on and off repeatedly every 10 seconds or so when I have AC turned on and fan on max. Again thanks for the post gentlemen!
4runn34 is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 08:17 AM #5
4runn34's Avatar
Real Name: Justin
4runn34's Avatar
Real Name: Justin
I finally got around to pulling the Climate Controller out of the dash and took it apart. After looking at it under a mag lens, I don't see any spots where the solder has cracked. Are you just touching up the existing solder points with the iron? Or are you actually adding more solder to each connection of the chip?
1999 Toyota 4Runner Limited
Old 07-05-2019, 05:22 PM #6
Browndirt Browndirt is offline
Browndirt is on a distinguished road
This is great advice. Just brought one back from the dead with this procedure. Whose leg do I gotta hump for a wiring diagram to one of these units.??? Have no power to the 2 small lower background button bulbs
Browndirt is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 07:53 AM #7
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
Finally pulled mine apart and attempted a repair. For a couple of years now I
guess, it's been partially working- temp and blower control, but nothing else.
Fortunately, it's mostly been fine, except when I wanted to direct air through
the dash and not the floor.
So I pulled it apart as described, though I first melted slots in the white cover
to get it past the display wires, then clipped the residue. I spent quite a bit of
time inspecting things and saw no broken or cold solder joints, so I decided
to just reflow the terminals for the wire connector from the back (circled in
red). As of now, it appears to be working fine.
In the time it's not been working, I've also had a mildew smell, which I think
is a function of the system not going through its initial cleaning cycle. Today is
the first time since the ATC went on the fritz that I didn't get the smell.
DIY Climate Controller Repair -How to-atc-jpg
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 10-20-2021, 03:02 PM #8
heat's Avatar
heat's Avatar
And for an update, my repair lasted exactly one day. I haven't bothered again.
Old 01-15-2022, 04:24 PM #9
Eric Liu Eric Liu is offline
Eric Liu is on a distinguished road
hello,please help,I want to test my climate control and I dont know how to connect the positive(+) and negative(-),thanks
Eric Liu is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 09:26 AM #10
rare_individuall rare_individuall is offline
rare_individuall is on a distinguished road
Hey guys, I did the solder trick worked awesome but now temperature control knob is now stuck at one temp, I soldered what I thought where the connection points for that but still no luck. Any suggestions?
Thanks in advance.
rare_individuall is offline   Reply With QuoteReply With Quote
Old 08-14-2022, 10:19 AM #11
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Thanks in advance.
Check for solder bridges between points you soldered. Irons that most people have tips are blunt pointed,
a tapered point think #2 pencil with tip just a touch flat on point.
Can be done using a 4"-6" fine file on iron you have. Luck
Old 11-08-2022, 07:11 PM #12
turkey_towner turkey_towner is offline
turkey_towner is on a distinguished road
Thumbs up Big thanks to both @Jungoes & @Wishmun!!!
Wow, big thanks to both @Jungoes & @Wishmun for this fantastic guide! After suffering for years with the stubborn climate control on my 2000 4Runner, I finally got around to solving the problem by following this awesome guide.
My climate control now works like a charm!
Thank you so much for documenting this!
turkey_towner is offline   Reply With QuoteReply With Quote
Old 03-05-2024, 06:31 PM #13
Shallom1 Shallom1 is offline
Shallom1 is on a distinguished road
It Worked!! Thank you
I created an account just to say thank you for the guide. I touched up what was easily accessible with my soldering iron making sure not to accidentally connect leads. I cleaned up the board with a little bit of isopropyl alcohol before installing it back into the vehicle. The only downside I had was that I was not careful enough when removing the paneling and some panel pieces ended up breaking and cutting my finger.
Shallom1 is offline   Reply With QuoteReply With Quote
bend , buttons , connections , issues , solder
Auto Climate Control Repair Services JRZEE2000TR4LTD 3rd gen T4Rs 154 12-11-2023 10:24 PM
Need my Climate Control Board fixed, who from Ebay did you use for your repair?? LittleCaesar 3rd gen T4Rs 0 12-05-2016 07:26 PM
Crazy Climate Controller idea with ARDUINO board Jungoes 3rd gen T4Rs 6 04-26-2014 04:09 PM
99 ltd climate controller issue lhloy 3rd gen T4Rs 0 05-08-2011 08:40 PM
2002 3rd Gen A/C - climate back lighting repair FateOne Problems & Warranty Issues 0 01-30-2008 09:13 PM
