02-03-2019, 10:52 PM
Broken/snapped caliper bolt
As part of getting ready for the Tundra brake upgrade, I began removing the bolts needed to remove the calipers. I got three of them out with a breaker bar but of course, one ended up snapping off inside the caliper
I've been searching T4R as well as Google for the past half hour but am not finding a consistent solution. Should I plan to work through the advice on Second Chance Garage or does anyone have different advice? I don't own cobalt bits, extractors, or a torch.
Thanks in advance.
02-03-2019, 11:01 PM
Real Name: John
Real Name: John
Thanks in advance.
It's broken in the spindle correct?
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
02-03-2019, 11:44 PM
Correct - it's in the photo above.
02-04-2019, 12:08 AM
Real Name: John
Real Name: John
Can you still get the caliper off?
02-04-2019, 12:31 AM
Real Name: Leon
Real Name: Leon
You can try to wiggle the caliper off, but the broken portion of the bolt may prevent that. In worst case scenario, since you're going TBU anyway, you can separate the two caliper halves from each other by removing the other four bolts, then you'll have access to the portion of the bolt that's broken off (assuming it's protruding out of the spindle).
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
02-04-2019, 12:33 AM
Yeah, I wiggled it quite a bit but the caliper won't come off. Disassembling the caliper itself is a great idea, I'll give that a shot tomorrow.
02-04-2019, 08:53 AM
See if you can fit a hacksaw blade in between the caliper and knuckle. It won’t be quick but should work. Maybe even try using a sawzaw if you have one.
02-04-2019, 10:35 AM
Real Name: Mark
Real Name: Mark
Disassembling the caliper itself is a great idea,.
That will get caliper off, tricky part is getting bolt out, stating the obvious I know.
DIYing this one requires some skill and equipment or you'll end up in worse shape needing a different spindle.
I don't see you getting bolt out using easyout, it gaulded bad enough to break bolt that size.
Was me, Tear it down take spindle to machine shop let them set it up in Pro drill press or milling machine drill it out chase threads with tap.
How lucky are you feeling?
02-04-2019, 10:54 AM
Real Name: Leon
Real Name: Leon
Agreed. With the caliper disassembled, you'll have (hopefully) a portion of the bolt shank sticking out. I'd try a bunch of penetrating oil, then maybe some serious heat, and then put a pair of vise grips on it and see what happens.
But as stated above, if it keep resisting, then taking the whole spindle off and bringing it in to someone with proper tools would be the next step.
02-04-2019, 11:01 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Man that really sucks!
Considering it generated enough force to snap, I'm guessing it's probably seized in there.. Even if you have enough room to grab on to the bolt with locking pliers it may not budge. Definitely worth a shot before having to drill it out.
Which leads me to the next option. Like
@ 96RedRunner
mentioned, it might be better in the long run to take the whole spindle somewhere to get the bolt drilled out and then the hole re-tapped. Drilling out bolts like this can be really tricky and time consuming.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
02-04-2019, 11:22 AM
Real Name: Leon
Real Name: Leon
@ 96RedRunner
Definitely words of wisdom. The chances of getting it out with locking pliers are small, but at least you can try, after getting some oil and heat on the threads.
I recently had the joy of removing a stuck Lexus O2 sensor - no rust, but completely galled in place. It just would not budge. After lots of heat and penetrating oil, it moved with about a million foot pounds of torque, but it turned out that the hex was being rounded, rather than the sensor turning (and that's with the proper O2 socket). I decided to sacrifice the socket, and welded it to the sensor. With another million foot pounds of torque, I saw motion of the sensor - but what I finally took out was the sensor body, the rest of the threads stayed in the exhaust manifold! I've never seen anything like it, it literally stripped the threads right off the sensor.
Ended up having to drill and tap for a M18-1.5 helical insert, THAT was fun doing in such a confined space.
02-04-2019, 01:40 PM
Real Name: Mark
Real Name: Mark
That bolt sticks through the spindle mount leaving exposed 2-3 threads to rust.
That's what seized, You won't unscrew it you'll have to turn it to the right and go out back side.
With it seized enough to break bolt the nub left won't be enough to grip with whatever and remove it.
Different vehicle I had this happen, I welded a nut to nub broke nut off.
DIYing sometimes you gotta go for help or get really lucky.
02-04-2019, 01:54 PM
Depending on what you have access to, this be a candidate for center punching and drilling out with standard drill bits. At some point, the drill be might grab and just push the stub out the back side.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-04-2019, 03:08 PM
Thanks, everyone, for your suggestions so far. I think 96RedRunner nailed it - here's the other side of the bolt:
I was going to get left-hand drill bits, though it doesn't seem like it makes any difference which way (CW/CCW) I try to turn this thing. I thought about the hacksaw option but I don't think I can get it in there to attack the seized end of the bolt. Taking the caliper also won't help in this case. I'm planning on picking up a center punch and a few cobalt bits tonight and going to town.
02-04-2019, 04:06 PM
Real Name: Mark
Real Name: Mark
Good on you giving it a shot. Since your buying center punch look for the set that steps up like drill bits.
If you can't find step punches get one with a round shank wrap tape around it.
Then you can use caliper hole to get on center, that's a critical point when drilling a bolt out.
I'd for sure get a 1/8" bit or so for a pilot bit to start.
You may know all this just saying, don't envy you with this PITA job good luck.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
