Originally Posted by Pekoe1111
Can I remove the upper seat covering and foam without removing the seat from the truck? I know the seat only has four bolts, so is it easier all the way around to just take it out?
You can pull the upper covers with the seats in the car. Unclips at bottom back, then two ring clips halfway up. Sleeves for the headrests have clips at bottom of tubes holding them. Although you don't need to pull the covers completely off past the headrest tubes.
I, too, found the amount of lumbar curve ridiculous. Like driving with a basketball behind me. I pulled the little extra piece of foam out, and added a thin piece of foam above the lumbar area so that my upper back leans into something other than air space. Much more comfortable.
