Originally Posted by nissanh
Make sure to use OEM seals.
Did you use OEM valve cover gaskets and circular seal at the back of each head? I replaced the valve covers with non-oem sometime ago and saw a leak between transmission and engine and I too was thinking about the rear seal and then I noticed those non-oem valve covers are leaking in the front of the engine and redid all that again with OEM. I don't see any new oil between the trans and engine.
No need to pull manifolds. Check the condition of heater core hoses and replace those as those are located behind the engine.
Pretty sure I used Fel-Pro. But I checked all around the valve covers and around the top of the engine bay in general and it's all dry.
