02-11-2019, 07:49 AM
Seat belt strap to fraying and needs replacement.
With over 243,000 miles on my 4Runner, my seat belt strap is fraying and the slide catches where it's frayed. Is the strap replaceable, or do I need to buy the whole seat belt unit? I have a 1996 SR5 with Taupe/Oak interior. Thanks for any help.
Ben
1996 T4R SR5 4wd 5speed manual 3.4 V6
Evergreen Pearl w/ Taupe cloth
265/75 16 BFG AT T/A KO2, E load
297,000+ miles...
02-11-2019, 11:33 AM
You'll need a new seat belt! I need one for my wife's, and for mine, same color!
Oh and one for the Tacoma, and one for the Corolla, may as well get a six-pack while you're there!
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
02-11-2019, 04:09 PM
Real Name: Austin
Real Name: Austin
yes the seatbelt is replaceable. you don't have to buy the entire package, the belt itself can easily be unrolled and spooled again. but the easiest and probably cheapest would be just going to a junkyard and buying one.
1997 4runner, OVER 360K miles, Bilstein 5100 and FJ80 suspension, Polaris light bar, custom full length roof rack, plus some interior mods
I've had more 3rd gens than I can count at this point
02-11-2019, 04:56 PM
I actually found a decent one at a salvage yard from a 98 today (3/6). For less than $15 and 3 bolts, I'm good to go! Thanks for the replies!
Ben
297,000+ miles...
02-11-2019, 06:14 PM
Seat Belt Repair Service After Accident - All Makes & Models!
My brother has used this company to repair seat belts on his '97 4Runner and on his '07 Audi. (He has a border collie with seat belt anger issues when left alone for a few minutes.)
02-11-2019, 06:33 PM
If you are getting used/junkyard parts, make sure you get the right one.
The front seat belts changed in '99 to have a pre-tensioner squib in them - so, '96-'98 are compatible and '99-'02 are compatible.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-11-2019, 09:49 PM
I'd want a good look at the vehicle the used seatbelt comes off of. I'd just buy a new one. I also want to say that after getting a 1998, I think the seatbelt part number is different from 96-97. This isn't to say it wouldn't bolt in and work. But I would double check.
02-12-2019, 02:53 PM
I need this
I have at least two vehicles could use a new belt and maybe get the retractor cleaned up since it's a bit slow to return.
02-12-2019, 04:56 PM
Do the company(s) who offer the replacement webbing service have DMV approval ratings? I would assume so because it's a huge liability issue but I'd hate to install new belts that aren't DMV approved and then sell the vehicle to an unsuspecting buyer who then gets in an accident and the stitching fails. Could you potentially be liable if you install a product that is not DMV approved?
I know its a remote chance of all that happening, but let's face it off-roading can be dangerous - vehicles and occupants can be exposed to more risk.
I am considering replacing my wife's Sonata webbing because she managed to get it caught in the door and it cut the webbing. Currently not letting her drive it!
I have sent an inquiry to one company about the issue of DMV approval.
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
02-12-2019, 05:28 PM
These are the folks to use! They can not only replace the belt but check and repair all the tensioners and squibs for only $65!!!Q
Seat Belt Repair & Airbag Reset - Safety Restore
02-12-2019, 09:59 PM
In CA the DMV does not "approve" anything. No such thing, and no government agency regulates companies doing these repairs.
02-13-2019, 01:15 AM
DMV approval?
Where did you get this information? Any links to this? I never knew DMV can be involve in this kind of repair. Maybe BAR?
02-13-2019, 01:32 PM
If anything it would DOT or NHTSA, not DMV...
02-13-2019, 02:06 PM
Real Name: Nelson
Real Name: Nelson
Im going to get new belts from the driver/passenger on my 98. My driver is literally patched together with another piece off of another car cause it doesn't even match the seat belt. Talk about a hazard waiting to happen.
02-13-2019, 04:04 PM
Ok, got that...so to the question - are these companies compliant with ANY and ALL regulations?
Again, I assume so but I have asked the question directly to one large company who do repairs and so far radio silence.
Mark
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
