Old 02-13-2019, 04:17 PM #16
violation's Avatar
violation violation is offline
Real Name: roGer
violation is on a distinguished road
violation's Avatar
Real Name: roGer
Originally Posted by BamaDrewski View Post
These are the folks to use! They can not only replace the belt but check and repair all the tensioners and squibs for only $65!!!Q
Seat Belt Repair & Airbag Reset - Safety Restore
i have used these guys with good results as well.
2002 Toyota 4[thedog]Runner Limited BFGoodrich KO2's | Taco whip | Paranoid Fabrications switch panel | full length roof rack | Tundra brakes with SS lines | ARB Awning | ARB compressor and f/r lockers | ToyTec lift (ugh) upgraded to Kings | Total Chaos UCAs | WARN winch | 4xInnovations armors | Method Grids | KC Roof Lights | Lotus Development CV Axles | Whiteline Bushings | Spidertrax spacers | SnoMaster Fridge | ReadyLight | holy shit this adds up fast
Insta: wkendnomad | this is where the adventure begins
violation is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 05:18 AM #17
Benski's Avatar
Benski Benski is offline
Benski is on a distinguished road
Benski's Avatar
Originally Posted by T4R2014 View Post
I'd want a good look at the vehicle the used seatbelt comes off of. I'd just buy a new one. I also want to say that after getting a 1998, I think the seatbelt part number is different from 96-97. This isn't to say it wouldn't bolt in and work. But I would double check.
Thanks for the reply. You are right. I found a decent seat belt on a 98 at a salvage yard. The mounting plate with the retractor is larger than the one I took off of my 96. The larger 99 mounting plate has another hole for an additional bolt that lines up with a bolt hole in the pillar frame like it was made for it.
Ben
1996 T4R SR5 4wd 5speed manual 3.4 V6
Evergreen Pearl w/ Taupe cloth
265/75 16 BFG AT T/A KO2, E load
297,000+ miles...
Benski is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 12:39 PM #18
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Why would you put a 20 year old piece of safety equipment on your truck?
All fabrics deteriorate with age, heat, UV exposure, chemical exposure, mechanical stress. Who knows what that junkyard belt went through before being scrapped.
My 2000 needed a new driver side belt last year because it was frayed. Got an OEM, and my mechanic installed it for me. I forget the exact price, but installed it was under $100 and worth it to me.
Old 03-07-2019, 02:49 PM #19
Polargeist Polargeist is offline
Polargeist is on a distinguished road
You can get one for $190 from toyotaepartsstore or whatever its called. I just got mine with some fender liners for about $300. all genuine toyota parts, so you dont have to worry about its safety. Totally worth it IMO.
Polargeist is offline   Reply With QuoteReply With Quote
Old 10-02-2019, 10:23 AM #20
TXdragon4runner TXdragon4runner is offline
TXdragon4runner is on a distinguished road
Thanks for the heads up on the vendor. I sent in driver side belt from my '02 4runner. great job and quick turn around.
Southlake Carrol Dragon 4Runner - North Texas -
- 1999 4Runner 2.7 - 5 speed - 2wd
- 2000 4Runner 2.7 - 5 speed - 4wd
- 2002 4Runner 3.4 - auto - 4wd
- 2002 4Runner 3.4 - auto - 2wd
TXdragon4runner is offline   Reply With QuoteReply With Quote
Old 10-02-2019, 10:26 AM #21
yeah, or 75 bucks I got new webbing and the vendor cleaned the retractor mechanism. I was going to pull from a pick a part yard but after thinking it through, who knows what stress those belts were put under or the webbing rotting from the UV?weather exposure. Talking about a seat belt that is intended to limit damage/save a life. 75 bucks for new webbing is wise investment.
Old 01-20-2022, 03:07 AM #22
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Originally Posted by phattyduck View Post
If you are getting used/junkyard parts, make sure you get the right one.
The front seat belts changed in '99 to have a pre-tensioner squib in them - so, '96-'98 are compatible and '99-'02 are compatible.
Do you know if the drivers side and passenger side are interchangeable?
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 01-20-2022, 10:00 AM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I don't think they are and that's a very good question.
Checked part numbers are different. I believe the spools are mirrors of each other is the reason..
Old 01-20-2022, 10:13 AM #24
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
My 99 has different belts on both front sides, not the same number.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 01-20-2022, 08:38 PM #25
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
Seat belt strap to fraying and needs replacement.
I just changed my drivers belt because it was fraying. My truck is a 98 and the guy local to me had a 97 & 99. He checked both and the 99 was f-ed up and worse than my 98, so I took the 97 witch was in perfect condition.
Here’s a picture of my belt
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 11:22 AM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That belt is done. At the pick and pulls guys use seat belts to lift engines and transmission out.. lol...
Old 01-21-2022, 12:38 PM #27
Elgin Elgin is offline
Elgin is on a distinguished road
Anyone know the length of the webbing for a 97? Theres a website that sells it buy the yard in a bunch of colors. I want to do all 4 and I can do the cleaning myself. Did that in a 02 celica a year ish ago.
1997 sr5 3.4L Automatic
Elgin is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 02:55 PM #28
busmup808's Avatar
busmup808's Avatar
I picked it up for $20. I also picked up a maf and stock box from the 99 4runner
belt , buy , fraying , seat , strap
Replacement seat belt options? Also sealer around fender flare? funstuie 3rd gen T4Rs 6 05-09-2016 09:50 PM
Seat belt replacement luke150 5th gen T4Rs 8 11-23-2015 09:28 PM
where can I find a replacement seat belt? hrt4me Classic T4Rs 0 09-13-2011 08:40 AM
Seat Belt Replacement Scaiza1 Maintenance/Detailing 0 08-07-2011 12:47 PM
seat belt replacement from newbie skypilots General Discussions 6 12-05-2010 05:55 PM
