Old 02-11-2019, 09:09 AM #1
TurtleAdventure TurtleAdventure is offline
TurtleAdventure is on a distinguished road
Shutter at 55 and up
What do you guys think about this.
98 SR5 4x4 automatic all stock, 160K miles. Basically it is my winter car and some random other season driving.
Anyways. It shutters at 55 and up kind of bad. It was doing this and I felt steering vibrations and shake. So I new LBJ, UBJ, outter tie rods, new tires, rims, alignment.
Now there is nothing in the steering. There isnt even any slack in it. Going 55 shutter starts and I can let go of the wheel and it goes straight. I dont even feel much in the wheel. But the whole truck is shaking.
Anyone else have something similar? My guess is something in the drive line like a messed up drive shaft.
Thanks friends
Update
Interesting thing happened. It drove smooth at 70 on my way home. I hit a pothole and it started with the vibration/shutter again. Then again a few potholes latter 70 and smooth. When it isnt ice and snow everywhere I will jack it up and see what is loose. Hopefully and easy fix.
TurtleAdventure is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 11:09 AM #2
Outrider Outrider is offline
Outrider will become famous soon enough
I ran into an issue like this, years ago. I thought my engine was about to explode or implode. With some research on this forum, either by searching tons of posts, or by asking questions (I don't recall which method), I found out that it was the u-joints of my driveshaft.
The way I confirmed it was to crawl underneath, and grab the shaft near each u-joint and give it a good shake. If you feel any movement when you shake it, then it must be that u-joint. So, I suggest you try that.
I ended up repairing that $1,500 driveshaft for about $100, including the arbor press that I needed for the job, and kept mounted to my workbench, for future use on other things. If I recall, the new u-joints cost me $50-$60, but they have Zerk grease fittings on them, and they are removable and replaceable. If they should ever wear out, which they won't, because I grease them every year or so. It was a pretty involved job, requiring surgically cutting out the u-joints, and pressing in the new ones. I have tools and am handy with them, but it wasn't an easy or simple job.
The OEM design is really crappy, as the u-joints are neither maintainable or replaceable without surgery. It is either the result of beancounters telling Toyota engineers what to do, or it is planned obsolescence.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 11:31 AM #3
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Thanks friends
The symptom you are describing can only be a rotating imbalance. The speed sensitive nature makes me inclined to point at the wheels or tires. I know you say you installed new tires and rims. Can you give more information about them? Either they are not balanced correctly(dynamic) or are faulty. Of course you could also have an issue with the front hub/rotor, as they rotate too.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 12:00 PM #4
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
You got any snow/ice build up in wheels? It's usually obvious but sometimes its not. Or has it been doing this pre-winter?
I like the other suggestions too (Ujoints or wheels/tires).
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 12:08 PM #5
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Im thinking driveshaft also since you not really feeling it in you steering and its tracking straight.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 12:11 PM #6
Me too, and the driveshaft is very easy and quick to check. Nothing to remove or take apart. I am fond of checking the simplest things first (took me a while to learn that - lol).
Old 02-11-2019, 12:28 PM #7
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
BTDT, was about to tear my whole truck apart until I went back to the basics - tires. Tires are a lot of mass being rotated at high speed, so it's the best place to start. New tires alone may not fix it, you should get them road force balanced (not every shop can do that).
Do that first, and see if helps - it's the cheapest and easiest place to start.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 12:47 PM #8
Vibration (BZZZZZZZZ) at speed is probably driveline - driveshafts/u-joints or transfer case and pinion bearings.
Shake (wobble, wobble, wobble) is tires or steering components (and sometimes alignment).
At least, start from those places.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-11-2019, 02:20 PM #9
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I'm with crowd saying driveshaft, mine would start at 45+ mph.
Ended up being U-joint at rear diff.
Old 02-11-2019, 02:28 PM #10
Thanks for this. yes Vibration not shake.
Old 02-11-2019, 02:29 PM #11
Thanks, I will check it out. Ive never had a driveshaft go bad and I looked at it but didnt see anything crazy. I will try shaking it. That is really the test of everything LOL
Old 02-11-2019, 06:55 PM #12
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
check the output shaft of the transfer case for up/down movement - there's a bearing there that can be an issue.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 09:16 PM #13
OP - just curious if you have identified the problem. Any success?
Old 02-18-2019, 03:05 AM #14
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
If shaking it around doesn't reveal anything, pull the rear driveshaft and pop it into 4WD. Get it up to highway speeds and you'll know real quick if it's the rear driveshaft or not. Did this to chase down a vibration I had and was able to eliminate the driveshaft as the culprit.
It's only 8 bolts to get the shaft out. Compress the slip yoke a little (push it towards the transmission) and it'll fall right out.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 02-18-2019, 02:09 PM #15
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
I had the same situation happen in my '98... A buzzing vibration(not shaking) that originally started at 60 and would disappear at 70 and just continued to get worse. I checked for play in the U-Joints an there was none to speak of... Turned out to be my rear U-Joint. After trying to diagnose myself and a few shops trying too I took it to a driveline shop and they tore it apart and found the bad U-Joint. Runs smooth now. My take away is there isn't always play in a bad U-Joint.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
drive , shutter , slack , steering , wheel
Steering shutter starts at 65 mph KeninSC 3rd gen T4Rs 19 08-17-2017 11:30 AM
Shutter when stomping gas 123preston123 3rd gen T4Rs 1 10-11-2014 01:32 AM
Driveline shutter after lift issues?? Oldcrustybritches 4th Gen T4Rs 3 06-10-2014 01:12 PM
Shutter Island..... 08medic4x4 Off Topic 7 02-24-2010 03:50 PM
3rd Gen Shutter mochilln00 Maintenance/Detailing 0 09-03-2009 06:07 PM
